CeramicGT001
I couldn’t even get that middle lower screw to budge with a thin screwdriver so had to hack the plastic around it. I did mess up the surrounding trim just a Little getting out the lower side screws (Armrest covers this trim when closed anyway).The install of the armrest is very difficult due to the location of the back Phillips screws on the armrest. Go take a look. Trying to get a screwdriver In There without damaging the aluminum console back cover is almost impossible. Clearly they intend the entire center console to be removed which is a bigger pita. Using a very small screwdriver (shaft) with micro fibers laid down helps.... but it is difficult to get leverage.
The main reason I went down this road is because the Oem leather armrest creaked and I tried adding foam to the inside but it didn’t help too much. The alcantara one so far has a much tighter fit and makes no noise.
