Lots of work to add a little badge. No hopefully the bumper goes back on as easily as it came off.
3M tape works great too ..........................but I digress ...............Bumpers go back on easily !!View attachment 27541
Did the badge come with its own clamps or what exactly? You should take pics of the mounting.View attachment 27541
View attachment 27543 Had to get this little beauty pulled yesterday morning. The onboard tire (tyre) pressure system worked great at detecting the problem. Pull into the lot at the club 35/36psi came out a few hours later and drving home notice back right 29 psi. Next morning 15psi, fortunately Northshore Tire is just around the corner from me. 25 minutes and 40 bucks later she was good to go.
Now that you have the front-end removal mastered........Time for the Velossa Tech Big Mouths.View attachment 27541
I believe that is the case. Unless I am misremembering and he doesn't have the intakes or whatever those big mouth (usually red?) things are called.Then one would think he would have known the ease at which it goes back on and not said "hopefully the bumper goes back on as easy as it as it came off".
However maybe he paid for the VT install.
Yeah, the bumper went back on really easily.3M tape works great too ..........................but I digress ...............Bumpers go back on easily !!![]()
you can see his "bumperless car " in the first pic , on the right side , in behind ..................no Velossa's thereI believe that is the case. Unless I am misremembering and he doesn't have the intakes or whatever those big mouth (usually red?) things are called.
Not a car guy, I repeat. But I have seen them behind the top grill.
Wish I would have bought the Velossa’s. That was the first thing that came to my mind once I had access to that area. Next order for sure.you can see his "bumperless car " in the first pic , on the right side , in behind ..................no Velossa's there
I have the K&N intakes and filters but not the Velossa big mouth inlets. That’s a different part. It will be the next thing going onI believe that is the case. Unless I am misremembering and he doesn't have the intakes or whatever those big mouth (usually red?) things are called.
For sure! Those would look great.Now that you have the front-end removal mastered........Time for the Velossa Tech Big Mouths.
Thanks Kamauxx. I liked how it turned out. Adds a little flare to the front end.I put one of those on my Optima. It was a PITA to install on there too. I don't think Kia likes us putting stuff on their grilles.
Looks good.
..so much weight gain .......................and now the door won't fit properly , the whistling will drive you crazy ............................really ???? BawaaaaaaaMassive hp boost with this mod!!
(Yes... I know. Not perfectly centered nor perfectly straight... I’ll fix this week)
View attachment 27577 View attachment 27578 View attachment 27579 View attachment 27580 View attachment 27581 View attachment 27582
