Lots of work to add a little badge. No hopefully the bumper goes back on as easily as it came off.
I put one of those on my Optima. It was a PITA to install on there too. I don't think Kia likes us putting stuff on their grilles.
Looks good.
Yup. I used 3M, took about a minute, 20 seconds to lineup 40 seconds to press and hold. However taking the front-end off to do the job would've certainly made me feel like I deserved the cold beer upon completion. :confused:
20190707_090543.webp Had to get this little beauty pulled yesterday morning. The onboard tire (tyre) pressure system worked great at detecting the problem. Pull into the lot at the club 35/36psi came out a few hours later and drving home notice back right 29 psi. Next morning 15psi, fortunately Northshore Tire is just around the corner from me. 25 minutes and 40 bucks later she was good to go.
View attachment 27543 Had to get this little beauty pulled yesterday morning. The onboard tire (tyre) pressure system worked great at detecting the problem. Pull into the lot at the club 35/36psi came out a few hours later and drving home notice back right 29 psi. Next morning 15psi, fortunately Northshore Tire is just around the corner from me. 25 minutes and 40 bucks later she was good to go.
I've often wondered how big a Canadian 5c piece is. Thank you for providing that screw for scale comparison! :)
I think @Gordo has those already. :D
Then one would think he would have known the ease at which it goes back on and not said "hopefully the bumper goes back on as easy as it as it came off".:geek:
However maybe he paid for the VT install.
I believe that is the case. Unless I am misremembering and he doesn't have the intakes or whatever those big mouth (usually red?) things are called. o_O
Not a car guy, I repeat. But I have seen them behind the top grill.
you can see his "bumperless car " in the first pic , on the right side , in behind ..................no Velossa's there
Wish I would have bought the Velossa’s. That was the first thing that came to my mind once I had access to that area. Next order for sure.
I have the K&N intakes and filters but not the Velossa big mouth inlets. That’s a different part. It will be the next thing going on
Looks good.
Thanks Kamauxx. I liked how it turned out. Adds a little flare to the front end.
