oddball
- Sep 19, 2018
I made a video where I tried to explain and show the internals of the transfer case.
I don't know why there so little videos on youtube on this transfer, so I decided to try upload one.
So, it seems like the wave spring pushes against friction disks and provides AWD feature all the time. Not sure how many % does it send to front wheels, but definitely not more than 50%
The only way how these disks may get overheated is through uneven amount of rotation on front and read wheels.
Also, if you got an AWD problem dashlight, it's either oil pressure sensor failure or oil pump failure. Both are easy to fix.
Excellent video, thanks for recording and posting!
For the clutches, the ones that engage on the outside and are just plain steel are called "steels", and the ones that engage on the inside and have friction material are called "frictions".
Next time, spread out the clutches. You want to make sure the frictions aren't burnt or flaking apart, and make sure the steels don't have hot spots or are warped. It can be difficult to tell how much friction material has been worn from the frictions if you don't have a new one to compare against. Usually a transmission builder would assemble a clutch pack and check the clearance, then replace parts as necessary to get the desired clearance.
In this case, I expect that if you assemble the basket with the pressure plate (the thing you called a "cap" on the basket) and WITHOUT the wave, there should be a very small clearance between the basket and the lip of the pressure plate. That should be just slightly larger than the actual thickness of the wave.
Of course, I'm assuming that pressure plate doesn't have any flexibility and the bottom inside of the basket doesn't either.
That wave spring is not enough to engage the clutches. Sure, I bet installing the rear cover does compress the wave plate, but it's not going to be the entire distance. That is just to cushion the engagement so it's not harsh. Many automatic transmissions include wave springs or steels in various locations depending on the design of the trans. Many of the parts in that area are identical to an automatic transmission, and all the concepts are the same.
There's definitely an ability to change the AWD split. It's quite common to pull the "AWD Fuse" and run the car on a 2 wheel dyno. That fuse powers that oil pump. So no oil pressure = no power to front wheels.
It looks like there is a piston in the rear cover. This piston doesn't rotate, so it presses against that large torrington bearing, which presses on the basket pressure plate, which engages the clutches. It's difficult to tell how that comes apart as I'm not seeing an obvious snap ring in the video.
But, that must be a piston. The clutches need to be applied from one side or the other. The other common method is to feed oil through a shaft then through seals into the basket and have a piston inside the basket. That's obviously not the case here. So the piston must be in the case. (ha ha)
ACTUALLY! Spoke (typed) too soon. Looks like the piston might be on the back side of the mid case. I see a snap ring there. That could then push the entire basket against the rear case. Not certain about it though. Note that the piston only needs to move a very short distance. The standard rule of thumb is 0.010" per friction, and looks like there are 9 frictions, so about 0.090" or about 2mm. The fluid acts like a lubricant so the plates are designed to just float past each other unless there's enough pressure to squeeze the fluid out. Given the intent of this clutch they could easily design it to be closer, like 0.040" or 0.050".
On third thought, I'm convinced the rear case has the piston. There doesn't appear to be a provision to manage the rotation of the basket on the mid case, and it appears that when the basket is pushed forward, that large shoulder on the transfer gear engagement actually presses on the transfer gear. So the basket bottoms out there, instead of pressing on the mid case. But that doesn't answer WTF there's a snap ring on the mid case.
AWD codes could also be due to readings from the speed sensors that the ECU doesn't like.
My assumption is there's a fixed lube orifice. Run the pump at or below a certain duty cycle and it only moves enough oil to lube the clutches and gears. Higher duty cycles progressively increase the clamping of the clutches.
Torque split is due to two factors: a) slippage of the clutches, and b) design of the gearbox. Wet clutches don't enjoy partial engagement, so I doubt they do that a whole lot. Especially under power. I mean, it's possible, and it is done, but the design life will be pretty short. There's quite a few frictions in there, which helps, but they're small. For comparison, an overrun clutch is usually 2 frictions, a forward clutch is usually 4 frictions, and a direct clutch can be anywhere from 3 to 6 frictions.
The design of the box includes the gears. That intermediate gear is freaking huge. Some of that is to get enough distance so the forward shaft has clearance, but I bet that also factors into the torque split.
I find it very interesting that they use taper bearings on the intermediate gear.
The holes in the hub (at 7:00) and the slots and the basket are just for lubrication. ATF is also a coolant - you want ATF flow between disengaged plates to cool them.
You said initially the wave was broken when you opened the unit. I expect that was the first failure and broke due to manufacturing fault (hairline crack, bad heat treatment, whatever). The chunks then clogged up the filter which reduced oil flow which caused things to get hot and start melting.
There's a couple of other interesting little design features that I'm not entirely sure how they factor in:
1) The teeth on the basket that engage the transfer gear are much wider than the teeth on the gear. At first glance I thought the engagement teeth on the gear were a synchro!! That implies they expect the basket to move backwards and forwards quite a bit.
2) The engagement teeth on the transfer gear aren't fixed to the gear. When you turned the gear train back and forth I could see there's a little bit of play between the two. That's a bit odd as I would have assumed that would be a single forging. Or, well, powdered metal casting these days. I'm curious if there's more going on in that gear. Just seems like a minor bit of unnecessary complexity. Actually I take that back - with a replaceable interior, that same gear part number can be used for the transfer gear and the output gear, with the output gear having a different insert that engages the output flange. Still, now you have at least 3 part numbers where otherwise there would've been 2. Hm.
