Tork Backend Flash
Here is a back end flash. Dropped .4 of 0-60 with 1000 worse DAs and less octane.
Original was map 8 e85. After flash map 6 straight 93. Adding some e85 next.
This doesn't add boost so no big LC improvement though not too bad 1.89 60s.
Even with no boost target increase ecu boost hits 18- 19 psi (catless FBO) and with spoof running 23 psi.
I still like full flash but .4 + off is good for $500.
Not quite top tier times yet but some altitude and heat. Also not snipping. 3.85, 3.9 snipped?
You can see by the Gs the 1-2 shift is better.
View attachment 37323 View attachment 37324
Is this on your awd stinger?
No someone in Texas.
I ran these this morning messing around cause my road was closed and the road got half way dry.
Sadly for rwd this is the best 0-60 I’ve been able to get on draggy. My best 60’ on slip is 2.109.
Very quick indeed
The back end flash car is AWD GT2.
Both back end and full tune will drop your 0-60 even if RWD. Torks rwd hits 1.90s with stock tires and 3.85 0-60.
Gee your 0 to 60 is quick indeed, were you running e85 to get that as well ??
I had been running just 92 and WMI the past few weeks but did add e85 yesturday so probably helps looking at my other times. But its been so damn rainy I seriously haven't seen a fully dry road in 3 or 4 weeks.
Here in Kelowna it has been a mixed bag of weather for sure and it will be nice to run on that Area 27 with out limp mode striking again lol I should get my ECU back in a few days but darn it is the crazy ass weather which changes so very quickly and when the roads dry up here , I will try a 0 to 60 launch and see if my new Tune is a bit faster or slower:: best for me on to date with my RS chip was only 4.52 on dragy, I may if possible see if I can get on John s Dyno if I need more tuning:)
I wish I could get those kind of numbers. Is he just using the standard lc that is factory in the car?
Seriously. Right below you in Portland.
This nonstop rain is starting to drive me crazy. Haha.
We made a few tweeks map 6 back end flash car. Added a little e85, like e20 or less and adjusted boost slightly.
Damn!
Still no brake snip, temps in the mid 40s +1000 DA, GT2 AWD.
.64 faster 0-60 over map 8 pre flash.
And with brake snip....
Nice
So why is it his map8 times so slow... I'm faster than his map8 rightnow
Nice
Map 8, 65 additive, e30 and often throttle close shifts. Not everyone hits the glory times i guess. Working now though. #6 in both 0-60 and 1/8th mile on the leader boards.
