WildBill
Saw this on FB last night. @TorkMe is looking at providing backend flashes to piggyback users.
This would take care of a myriad of issues piggyback users face which can't be overcome without flashing the ECU. But this backend flash does not adjust the boost or timing leaving that to the piggyback. This way you can still adjust your map on the fly for cruising, spirited driving, kill all, 93 Octane, E40, WMI, etc.
I think this is a brilliant move on Tork's part. Embrace those people that want to use piggybacks for their own reasons and work with them. The price is pretty good if you ask me, after all, they have to do the same amount of work to give you the flash. Cheers to Tork for moving the platform forward some more!
Here is the FB Post.
KIA Stinger 3.3 "back end flash"... who wants one?
Now, some of you may be wondering... what is a back end flash. Well, that is a flash you use in conjunction with a piggy back or some other type of signal modifier. I have acknowledged that the Stinger market is not going to get rid of their piggy backs, so we have made the decision to fall into the fold (or something like that) to get your guys cars running optimal with a piggy back.
What will our back end flash address?
1. Shift improvements. We will adjust shift timing and stop ignition drop. Thus speeding up the shift recovery, this has been good for .2 seconds in 1/4 mile times.
2. Increase torque limits, this should stop the throttle from getting closed on shifts. We have seen a lot of piggy back datalogs with the throttle closing on shift or the throttle closing in the higher gears due to torque limits being exceeded.
3. Tops speed limiter increased for those who have a 135 MPH limiter we increase it to 170 MPH.
4. Target lambda (air fuel ratio) will be set to one of the selected options you choose in the menu when ordering your tune. We will have 11.4/11.8/12.0 as options for your desired AFR ratio's. Custom AFR/Lambda targets will be an additional charge.
5. Stop cat over temp protection from kicking in and raise the fuel correction for turbine temps. We will have catted and catless options for these correction limits.
6. o2 code for catless/race cars cat delete.
7. Turbo speed limits increased (calculated not actual) to allow the full ignition spark delivery, so you no longer have to gap your spark plugs down to the .021 or smaller to get the piggy back to work properly.
8. Increase in coil dwell time to aid in proper plug gap and reduce spark blow out. This will allow for larger spark plug gaps to be ran without spark "blow out".
9. Increase max air flow limits... to stop the sudden "dead throttle" from happening when pushing the limits of the piggy back boost levels.
10. Low fuel torque limits increased to standard limits, so you can run at 1/8 of a tank when at the drag strip. This will not stop the factor fuel system from running out of fuel, or the fuel basket from getting sucked dry (fuel basket is the reservoir inside your fuel tank).
I need some feed back from the community if this is something they want us to offer. Starting price would be $495 (damn steal) plus shipping. With options, it would price out to $695 (custom requests from customers). We would not set or change anything in the boost management or ignition management, due to the piggy back controlling those parameters, but we can address all the limits that currently hold the piggy back from being utilized to its full potential.
Please let me know if you would like to see this as an option for the 3.3TT Stinger models.
Thanks,
Tork Motorsports.
Thanks,
Tork Motorsports.
