No, it’s common thing, lots of brands if not all these days wouldn’t let you lock your keys in the vehicle. Only Ford does it right with the key pad on their higher trim levels.It's a Hyundai thing. My mother's Elantra wouldn't let me walk away with the engine running and lock the doors either. That was the first time I experienced this.
Yeah, I’ve done the samething, hot wiring is a thing in the pass.Are you sure about that? I've driven the car a little ways without the key being in it.
Ok, so I found a fix. Club wheel lock, leave the car running put the club on and run into a store.The key pads also make Fords the most stolen vehicle make, especially the F150 as owners leave their keys in the vehicles and lock them with the keypads.
....................Trunk Monkey works better !!!Ok, so I found a fix. Club wheel lock, leave the car running put the club on and run into a store.
No you just need to be a little less rude. Not sure why you want it locked nobody's going anywheres with it. Theres probably a good reason for it though.
Why not just turn it off? You’ll conserve fuel and at least your car is still there waiting for you when you come back.
You will be able to do this with our Canbus Control Module that we are almost finished producing.
It should be available for sale within the next 2-3 weeks latest. (Most likely sooner)
The feature is called "Stop & Go" and allows you to leave the vehicle with it running and still be able to use the remote to lock or unlock the doors.
You can read more about this product on our K5 Optima Store website, where the product is sold for other vehicles. (Not for the Stinger yet)
However, it will give you an idea on the product and how it works, and it would be the same exact product for the Stinger.
Canbus Control Module - K5 Optima Store (Coming soon to the K8 Stinger Store website)
Actually leaving your car running is technically. TECHNICALLY illegal.
The car has a start stop system so I'm sure it was designed to be turned off and on a few times. But if you are just going to consider the negatives of starting the car again, you have to weigh it against the negatives of leaving it idling.I do not want to turn it off because it is not in closed loop yet. I do not want to continually put the car through a cold start.
Yes indeed.
Another technicality - stealing a running car is technically not stealing.
