terrelltechsup
Terry is dropping big ole nuggets in this picture BTW. I smell big things coming soon.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
The low pressure pump isn't a limiting factor, problem is with the high pressure pump. You'll need WMI or chargepipe injection, to support significant power levels.
I'm liking this. Would almost be like having port injection in addition to DI, might clean up those intake valves... All controlled by JB4?
Thanks for the info, @Terry@BMS !
Is the enough LPfp volume to support the additional injector without affecting the DI supply? Do you need the BMS port injection controller with this? Souls meth be removed or used in conjunction?Yes of course. And for those running E85 the Fuel-IT flex fuel kit attaches so fuel volume is metered automatically.![]()
Low pressure so far no issues, even running straight E85. But E50 right now is as much as we suggest due to other tuning considerations.
This may be early to ask this but are these CPI kits easy to install and remove for dealer visits?E30-E40 on map3 JB4 only is fine... It's higher boost levels like map7 and the stronger mixtures needed to hit them without timing drops like E50 that over burden the factory high pressure pump. CPI or WMI is required for those levels. CPI kit not released yet but coming soon.
What about people who do not have access to E85, is this still beneficial?
Awesome. Any possibility of you guys making another nozzle like the WMI kits that went in before that sensor?Like a WMI kit, maybe easier as everything is in the engine bay, but the chargepipe has to be drilled for a 1/8" NPT nozzle. We'll be placing the required port on our intercooler kits as well.
What would be the limiting factor? Turbos?No, on non-E85 fuels the fuel system is not a limiting factor.
Octane with non-E85 pump fuels. If you use unleaded race gas, the high pressure pump is able to keep up with the factory turbo limits.
Ok, so people with OEM turbos and no access to E85, WMI is still the best solution, right?
Correct
