Stinger Brake Pads Replacement
I am looking to replace my front and rear pads and I have narrowed it down to a few options after reading the thread, looking for some input to finalize my decision. Just looking for pads that suffice my aggressive street driving, no track use. I don't want any clunking from reverse to drive, and I'd like minimal brake squeal at cold temperatures.
1. CENTRIC Posi-Quiet 10521450 (Front, RockAuto) and CENTRIC Posi-Quiet 10560410 (Rear, RockAuto).
2. I was initially looking at K8 Stinger Store pads, however they are rebranded as Dynamic Friction Company (DFC) pads. Any input into this situation? I have heard generally good remarks about the K8 pads so I'd entertain the idea of them, but I much rather spend less and get the same DFC pads from RockAuto instead of paying a $150 markup at K8StingerStore.
3. DYNAMIC FRICTION 1551214500 (Front, RockAuto) and DYNAMIC FRICTION 1551214400 (Rear, RockAuto) these are their 5000-level pads. They also offer a kit that comes with new hardware. Would it be recommended to buy the DFC kit with new hardware, or re-use my existing OEM hardware?
4. DYNAMIC FRICTION 1310214500 (Front, RockAuto) and DYNAMIC FRICTION 1310214400 (Rear, RockAuto) these are their 3000-level pads. Does anyone have any experience with the 3000-level pads from DFC? Is there much difference between the 5000-level and 3000-level?
5. POWER STOP Z266012 (Front, RockAuto) and POWER STOP Z262144 (Rear, RockAuto). I haven't heard much about these, except that they clunk when shifting from reverse to drive. What is the consensus on PowerStops?
Any input on this handful of options would be great, any info is appreciated!
After wearing my OEM pads half way I bought the Powerstop Z26 +Hardware and really liked them (will be getting them again next time). They had the direction changing clunk, and I burned through them after 2 track days.
Then I bought the DFC 5000 1551214500 + 1551214400 pads and installed them with the Z26 hardware. They still have the clunk, and I find their initial bite a bit rougher than the Z26, too much for comfortable street driving.
I still have my OEM mounting kit and will try it on the DFC pads next time I'm swapping from my track pads (EBC blues).
ElChanclo,
How would you describe the brake dust on the DFC 5000 pads.
OEM mounting kit?
You mean the guide pins and retraction spring?
Those are just replaceable hardware.
ElChanclo,
I would say virtually none, I can't tell if it's just road dirt or a bit of brake dust. Definitely none of that dark red dust you see on some front wheels.
OEM mounting kit?
It's the only thing consistent between the clunk on the Z26 and DCF pads, might as well try it out.
Could be the clunk was always there, even on the OEM pads I just never paid attention till someone mentioned it. Could also be the brembo calipers.
I've had the DYNAMIC FRICTION 5000 pads for about two years now and the noise on them is awful. Any time it's not super hot out these breaks like to squeal for the first couple of minutes especially when reversing. I will have to try another set due to this.
I have the those same pads with no noises whatsoever, though I suspect there are several pads that fall under the exact same name. I suspect/guess they are not all made in Korea, and or China. So it is possible that I do not have the exact same pads that you do.
Did you resurface your rotors or replace your rotors at the same time that you installed the DFC 5000 parts
I replaced the rotors at the same time as the pads. All parts were from RockAuto
Strange that yours make noise...
I wonder what the difference might be.
I just received DFC5000 Ceramic pads from RockAuto for my '23 G70 3.3T SP AWD, along with new hardware. My car only has 15K kms on it, and the vibration has been present since around 12K kms. The front rotors were replaced by the dealer last week - they said the rears were fine, and there is no vibration now.
I notice that my new pad are all made in China, the 2145 (front) is GH and 2144 (rear) is GG; which is the opposite of the pads that @D.J. received a couple of years ago. So if I understand the friction codes correctly, compared to stock these pads should have more initial bite (G vs F) and more friction with heat at the front (H vs G) and same as stock at rear?
Also, are there any tips/tricks to this install? How to you guys retract the calipers, especially the rears?
thanks!!!
thanks!!!
It sounds like your understanding of the edge codes is correct...
As for tips and tricks for installing the pads, they really are straightforward and pretty easy. I suppose, just don't install the retraction spring upside down.
thanks!!!
I have the same pads, although mine are 5000 Advanced low metallic, supposed to be the same pad specs as the R1 Euro-spec. Easy install and unlike some of the aftermarket pads they fit just as oem, no slop in the caliper. My fronts are 1552214500 rears are 1552214400
Have been running them for about 15k miles now, no brake judder, better bite, but dust a bit more. Be sure to do a few cycles of pad bed-in to insure good initial deposits. I did 5 cycles 50 down to 5mph with each cycle braking firmer than the last.
Thanks! How did you retract the calipers, particularly the rear? Did it require any specialized tools?
Just push.
No special tools required. You can use a flat head screwdriver and pry against the old pads that you will be discarding.
The parking brake on our cars is a drum brake in the hat of disc.
