RUFFSTUFF
So what tire spec do you go with when you replace your tires and you didn't get OEM?
The same. Any tire made for these rims are going to have the same psi specs on the Stinger; Kia did the specs and the tires comply.So what tire spec do you go with when you replace your tires and you didn't get OEM?
Can you point to exceptions? I don't know of any myself.That's actually not correct, but it's close enough for most.
I just know what my rim and tire guys told me: 40 psi is what they inflate to unless the vehicle says higher. So tire differences are not the criteria; vehicle spec is what decides.
Not ignoring; modifying. They say 40 psi is better because it makes a high aspect ratio tire less likely to receive a damaged rim from potholes; while not be over-inflated. So firmer but not prone to center tread wear. I'm sure if the first priority were performance they'd probably be under-inflating according to the psi spec on the car.But your tire guys are ignoring the spec aren't they?
One owner. Meticulously maintained 15.5k. I inflate to 36 psi per vehicle placard. Just had a nail patched in rear tire. Fronts were 7,7,7. Rears were 6,3,6!!! This is NOT a previous owner or overinflation problem.
I've been watching my rear Pilot Sport tread wear. This center wear on the rear tires seems to be a consistent observation on these cars. Last week the depth showed 6mm across both front tires, and the rears were 5mm and 6mm on the outside and 3mm on the center.I'm anal when it comes to tire pressures: all four tires are inflated to EXACTLY the same pressure (meaning, there is no discernible difference in the needle's position at all).
I've done 36 in the winter, 35 in the summer, and yet the center tread on my rear tires is clearly wearing faster. I rotate my own tires, and despite my following specs, it still wears at the center quicker. This may be more related to factory suspension alignment specs and design than anything else. Meaning, it may be how the suspension flexes, the arch of the curve between various loads, etc.
