I have no idea what Watson Racing did or if it was the tips, but my car has almost zero drone to the point that it’s unnoticeable. I wonder if it’s vibration from the MBRP mounts that are causing it? Like stated before, Watson removed the factory mounts/bracing from my OEM exhaust and added them to the MBRP in the exact locations. The tips are the “Akrapovic” ovals from aliexpress that fit perfect.
If anyone In the area wants to go for a ride and confirm they are more than welcome.
Alright, I'll give you my address, be here by 7?
But really, I hope my shop hooks me up the same. I'll spend extra $ to have a great product. I got the round tips so some trimming is necessary, however the shop I'm going to has a fantastic reputation for its body work, so hopefully they can do it tactfully.
How much did you pay for install in case you dont mind sharing?
Around $400.... now keep in mind before you guys judge how much I spent, Watson is the same place that pretty much manufactures the Cobra Jet for Ford. I knew going in it was going to be a high $$$$ and was quoted appropriately. I purchased the exhaust used from a member here and screwed up by not cleaning it first, which I should have since I knew they would have to weld it in several locations.
Also, as of Tuesday when the dealer destroyed my side skirt, I have decided that no one is touching my car unless they have a reputation like Watson Racing. I normally work on, modify, and maintain all of my cars, except for exhaust, warranty work, or a flat repair. I was quoted on average around $200-$300 for the exhaust install, custom work, and tip install. Watson’s location of the tips is perfect and looks super aggressive. Both sides are a perfect match as far as height/length/etc.
Let the comments about how much I spent commence... haha. I will say this, you get what you pay for! I also received a tour of their facility which was pretty bad arse. I’ve never seen 20 brand new Cobra Jets in one location ready to sell.
No judgement...hell I was anticipating on spending ~$500 which I know is way above average, but I dont care. I just want it done right.
It mightttttttve been closer to $500, to be completely honest. I was surprised when I found out their labor rate was only $85.
I'm confused about what mods they actually did to your exhaust. The MBRP already has rods welded to it which pick up the OEM hangers. Do you have any additional info?
There are additional braces that the stock exhaust has that the MBRP is lacking. This can cause vibration and banging noises.
I saw people on Facebook talking about replacing the stock resonators with aftermarket in order to help with droning.
Any opinions on this or firsthand experiences? How about a suggestion for the part?
I had two extra resonators added. And the X pipe moved forward. It helped.
Just an update for the community:
ALL MBRP ORDERS HAVE BEEN SHIPPED OUT!
We currently have both the Aluminum version and the Stainless Version in stock now.
For any of you who were waiting to order until the backorder ended, now is that time.
Just an update, I installed the system and had pre-ordered some fiberglass tape expecting the drone to be bad with the factory tips. Without the tape it really wasn't bad, but in that low range with load, it was noticeable. With the different drive settings, it's not too hard to stay out of that range if you really care. If I hadn't pre-ordered the tape, I probably would have left it as is. Overall I am very happy with the sound, it's just what I wanted in terms of tone and volume, enough to be noticeable as more aggressive without having to worry about waking the neighbors.
Since I had the tape anyways ( https://www.amazon.com/gp/product/B01KVYH66U/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1, 1 roll is enough for 4 tips ) I went ahead and wrapped the pipes just ahead of the tips, then slid the roll up into the tip. What little drone was there is gone, it's almost like going back to stock as far as interior noise. I do not have any soundproofing in the hatch. The wrap has the added benefit of centering the pipes in the tips and looking better from the back, where now you do not see a gap between tip and pipe.
For more detail on what to do, here's what worked for me: I laid under the back of the car, took the tape and wrapped a couple of turns on the pipe, just before the tip, and put a metal zip tie on it to secure it. Then I just kept wrapping, tightening it every couple of loops, and testing it against the larger mouth of the tip. Eventually the fit is snug, and you can shove it into the tip opening about an inch if you shift the exhaust pipe to be centered within the larger tip opening. Then you can use more metal zip ties or baling wire to secure the wrap, both in a loop, and to the exhaust tip frame, so it does not unravel or slide back. Here's a couple of pictures of the finished product:
YI-m4OJD3daAhAvjqyx4RBE6Qvv7iWOaTr4pGoFtZEIaUsKHu7kEkgj8BksQGUurHXkfD5Ut3I_23byiYUxFhYRb2fUk4meLba6aQblfYA8grRRzJvoIMy97wRmfHizfh6TVQEyUtTmeYeC_a8geA5neoRJwty8Ggs2hyyUu6uq8oUeuXE5jFrT_5HiDAu1FXLChS9OCW60CWkPzspcJbM0kzS__z9fJ7tHvyVd7QvuJardEZJxtxmIGJg7tjA-JsPQ92-r60U8BVn66eYvy_RM2sEobj8FPFiBu-LxqUtMJT3LHRyUggT05ztAE-l_M3K5Rcp5X72dElHQj6s-ji6SsmweOArXRqu2Hs3DKogbi-J8KfzZErFb6cskcOtJXSIvtfUe1nP_BpUShJbLbefyyttBVWSv060PptyQnLa79XILpzpcWJJ1ipI6Su6ah9o3iE2EzxhZ-RrYH2O-X7D5B7Fqw_Hm0ogUfgaWCemOVkgamq3XLfSgXKRgrBsZ1EqULb82bbFjAj3OdUeotF_WUetSaS40jnZltHqKiQCQrsqy7yUThaFSJjFBBn-5f2olSNU8TWqScyYv79BqPXXgRgUDgOKcln6BByANf8-4JZ25tPuqpVsxAPE08tgXuBEz3nnXVqr_Vr_WqAdcCXf94okohOswS_KZfcw5xuS7sINXKT4GE=w2160-h1620-no
Loq8sym0QrSKJrL_sls3SnlmkR48xHhZP7p99-xMvTcTdtoxGbbxwtM7G9av5TapBpnwpQRNQ4kuCqar63Kml9KxNwXWNYHRcs4LtQanR_tCP7iOUWxbpQzz26rpPc072F-3r9P8QU_BqTUJeeYJuGM8ferUuSHTryH737bT0VpxzMDa6aVmrvwDJbnGkICsrAyE6vy33UxrelhqTHrk0w9n1NGFrdtIz6tvjOyrmD1tv0q_Ha0c_g-r6raR9i0opxx-fTmiVWirqrePp_wgAB56mPHZBD9qDYRwScbbP-HBoXyX9KG8d5cQz1RbxG0EyK8S11sCteaOCT1zGUy5aXdp10MRiQocEFD4j0DriVmHKQjRSgXhOCgwfREXvkLjbGNrYn785i7f7PplBn_vLQKS7-CM0R2ldvH4u2d5qOrS1ca6oOu951aQfORmZjp4ILxg5Dvz-HpouYUQD0McGAyajWtbk-fOoiddFQo9LoqZLVk9w8ZIPILAyy1npnZ8QKjERLXFJScsEjORQr5ScqrJEqYGG7WgfA6xMplrKEzL2C2PGTWXdLAkw8WIiCiyZ1B5vluxP8bPlxRQb_J7ZiJ7VTKdNGAgq_-ejQmMAC1-twVX9zYPCvSYqdOt9DBIDK4HzF_WtmrnsVZbPuYa1HYmIBt2HDOhh3njkQTmnVcactPgpcbk=w2160-h1620-no
I had to angle the flash just right to get the tape to be visible from the back, in every other case you cannot see it.
Hope this helps.
Hope this helps.
I didn’t do aftermarket tips either. I have that exact reverberation you talk about and it doesn’t bother me much either. I was thinking of wrapping the pipes, maybe later
Hope this helps.
Pictures don't come up. Looks like they have been deleted. Can you repost because I would like to try this fix. Thanks
Also interested in seeing the pics. Planning to get the MBRP exhaust at soccer point and want to see this fix!
Hope this helps.
Planning on doing them this weekend and painting the oem tips gloss black.
Suggestions for best intakes to match with MBRP Exhaust?
