Lozic ECU + TCU + AWD Tune
# 1000 spot since I can’t beat half the stingers on here at least take the #1000 spot
Noooooooooooo look I even lost at that
OK if bov is open/no hose to intake try and put hose back to intakes and tell me if it changes. Others if you have aftermarket bov and it releases atmospheric and recycles try setting it to more recycle than atmospheric. If you have atmospheric alone you may have to get it disabled
That is my problem, the bov hoses are connected and it's still always going and loud. I think I might just be getting old
Are you hearing it from bov or exhaust or intakes? where's noise coming from? Seems to me like the people having problems most have stock bov and it's hoses are connected. Is anyone having the problem with aftermarket or open stock BOV's I'm trying to narrow this down.
Very disappointed you got post #1000 I tried hard hahaha
 I didn't realize it was me. My bad man. If I delete it you'll be 1k :thumbup:
So, finally did a bar to psi conversion, LOL. 1.5 bar is 21.7lbs of boost. Basically what I am seeing on Map 7 with WMI. trying to figure out why we would switch from JB4 to Lozic. Maybe it's just more boost in 1st and 2nd gear and at launch. Since I'm RWD I'm thinking this is a no go. Once you are at 40 mph or so, is it really just the same? I guess I could see if you don't want to run Meth but want those boost levels, that could be good. Is the JB4 safer for the car in the long run though?
As I mentioned before... If you have JB4 no need to change to a tuned ECU but... TCU is another thing. TCU is needed with any tune...
Jb4 guys, another thing. I have done hundreds of logs and I still see that to much boost at higher Rpm´s slower down. Also to much peak boost as Ignition can go down and then stays there for several cycles.
This week I have done back to back tests for the settings "Auto Shift Boost Redux". It seems that shiftings will be slower with higher boost also and when you turn up boost by higher Maps or Map 6 shift is worse. I have found out that lower boost at shifts especially when you have raised boost is better.
JB4 settings from start is "60", I did put mine at "100" so boost will go down more to stock level when shift but car is faster and shifts better and more smooth. If this is at 100, stock ECU will not have a manipulated number.
Try it out! Change "Auto Shift B.. R..". Measure by Dragy and if we help each other we all get happier... and we find better settings. Now I will wait for my TCU from Lozic...
Thanks that was a slow track with 803ft elevation. That was a jaguar in the other lane.
Still very, very good in the Stinger world and what we have to play with! A 10 will be there soon!
I said I think I put no, couldn't find order form and couldn't remember questioning.
I verified with Lozic. Then when I sent back I got the 1.4 bar with reduced boost @ low RPM.
Boost
1.5​
Catalyst Heating at cold start ON
Installed Stop and Go, ISG No
Open Air filter Installed No
Exhaust downpipe installed No
Boost
1.5​
Installed Stop and Go, ISG (Idle Stop and Go) No
It is 20.3 PSI, will be more than enough... Good also to take of some torque in lower Rpm, that is what kills engine and drive train. Just shift down when you going to WOT. :)
The noise is more audible because of the intakes
