Anden L Schmitt
- Sep 11, 2019
I've only seen few people on here have boost creep or over spooling issues. Basically, the wastegate actuator doesn't signal quick enough to bleed off boost over the target generally when under more load than normal,comes such as going up a hill, downshifting into just the right RPM to cause significant load on the turbos ect.. I'm pretty certain it is a tuning issue. Unfortunately, most of the the tunes have catalytic converters in place or at least the primaries. Maybe contact the tuner with some data logging if that does happen to you to see if they possibly could correct it by sending you a remaped tune...
Have you seen a post on these forums about a fix where people adjust the wastegate? If you have please post it.
