The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Ideally I like to see a higher gear full sweep, and one shift. Like a 4-5, or a 3-4-5, where you start at 2000rpm or so.
Running too much boost for your octane may result in misfires, timing pull which will be apparent in logs, making less power than map2, etc. Not going to blow a turbo or cause smoking. I'd look to your bolt on hardware for that.
Blow off valve and dps are primary suspects, if you did an oil catch can kit those also can cause smoking if not designed properly. Tell me more about your blow off valve kit, did it use the factory control solenoid?
Turned out to be his timing cover gasket per the 2nd dealership he brought it to.I have no idea what that guys issue was or whether it was downpipe related. Never heard from him. Did he make a thread with what the issue was?
how do i send a cvs file i won't let me upload on hereIdeally I like to see a higher gear full sweep, and one shift. Like a 4-5, or a 3-4-5, where you start at 2000rpm or so.
In terms of map3 on 93 octane you'd want to look at the logs to evaluate it, but I expect it will work fine for most.
Clint Easterly said:Is there a BoV that's recommended? I miss my lame turbo sounds.
