Maddog2873
In case anyone was curious and hadn't tried it yet.... you do get great turbo noise when flooring it in reverse.....
Hm. Looks like it's for bitches only.For the insulation concerns, I'm recommending: https://smile.amazon.com/Joytale-Turtleneck-Studded-Sweater-Apparel/dp/B0776YMMBB/ref=sr_1_26?crid=3QGGEU6GRFVQA&keywords=dog+sweater&qid=1559155360&s=gateway&sprefix=dog+sweater,aps,196&sr=8-26
Sizes for all brands.
No concerns of heat since they have no heat shields? I do like the RED not fond of the blue.
You do realize that regardless of the Intakes and their level of heat shielding, the air they intake then passes through a turbine that is heated by exhaust fumes ( 7-15 times warmer than the intake air temp ) which is then fed into an air to air intercooler that cools the air before entering the inlet manifold right ? Whether the air is 80*F or 130*F pree turbo makes no difference when. It all comes out of the turbo super heated before being sent into the intercooler and cooled off. Either your front mount is efficient enough to cool the air post turbo or it isn't. The intake makes no difference.
Ye of little faithHm. Looks like it's for bitches only.
And bitches be like...
You feel better now?And bitches be like...
We there.You feel better now?![]()
How can people so wrong be so confident?!
Sorry, I disagree.
Compressing air increases its temperature.
Why Does Temperature Increase When Air Is Compressed Rapdily?
This has little to do with the proximity of the intake air to exhaust gases - turbos are split into two "sides" - a hot side (the impellor that spins the shaft) and the cold side (with the compressor wheel that is spun by the shaft). The shaft that joins them gets hot - but is generally water or oil cooled, and transfer of heat from the hot side of the turbo to the cold side is minimal, and has only a minimal (~20% without additional shielding - a turbo heat shield as installed stock on many cars helps here, a turbo blankey can help here, ceramic coating the hot-side can help here, and the impact of multiple processes here is additive in reducing heat transfer) impact on the efficiency of a turborcharger:
Heat transfer analysis in a turbocharger turbine: An experimental and computational evaluation
The air temp before the turbo makes a MASSIVE difference to post-intercooler temperatures (not to mention the performance and efficiency of a turbocharger):
Turbos and temperature – summer weather and turbocharger performance - AET Turbos
In summary - the colder the air that you feed a turbo-charger, the more efficient the turbo is. The more efficient the turbo, the better it builds boost pressure and the less heat it creates in doing so.
Post-turbo cooling produces a temperature differential - if your post-turbo temps are 150C and your intercooler can pull 50C, then your intake manifold temperatures will be 100C. If you can get the post-turbo temperature down to 100C, then the manifold temp will be 50C - that's a massive difference.
tl;dr: The colder the air you get into the turbo, the cooler the air will be that is used in the combustion process, and the better overall engine performance will be.
How to combat performance drop due to hotter ATMOSPHERIC AIR TEMPS
I really did enjoy the part where you explained how a turbo charger ( made out of metal, one of the most effective materials at exchanging temperatures via air and liquid lol ) has 2 Chambers. You don't say! Could those 2 Chambers also be adjacent to one another, and connected by the same solid material that is prone to heat transfer I talked about ? Oh.. it is ? And you're saying the turbine itself is connected via a metal shaft that is on both sides on that turbo.. which also transfers heat way too efficiently into the cold side ? No way... I had no idea lmao. Thank you for explaining my point further.
As air temperature increases the density of the air, and the amount of oxygen it holds, decreases. This means that the turbocharger has to work harder, spin faster and compress more air to produce the same amount of boost it would at lower temperatures.
Aww look, a newb. Is the stinger your first vehicle with a turbo(s) ?
Seriously, gents.Don't be like that. Argue the point, not the man.
Seriously, gents.
Point taken. Not saying I don't appreciate discussion/disagreement on a topic. But if I want to see personal attacks between strangers I'll head over to Twitter.+1. I preferred the other direction this thread was going. Can we get back on topic? Dog blankets anyone?
