Thrashmetl
 - Feb 26, 2018
Sorry I read your previous posts but did not read your name (did not match your last post with previous ones). You have much better idea than me. I just started exploring.
I was asking for thickness because if I fit both 1/2 inch thick sheets, I would end up at 1 inch total thickness. So was just trying to get an idea what can fit till it's an issue (may be to put spare in).
BAM XXL looks interesting. Can find it for 340 for 2 square meter (slightly more than 32 square feet). 32 square meter of Dynaliner + Dynamat combo would cost me 340. LUXURY LINER PRO from second skin (that would cost me $240) looks something similar (or is just barrier) but doesn't have adhesive and I assume won't be as good (as BAM XXL).
Is there something similar (to BAM XXL) that's cheaper?
PS: I don't listen to loud music, so I won't be creating vibration through sound system (if that's relevant).
We all start somewhere.
There's nothing special about me that's led to me knowing what I know - I've learned it over the years through exposure to various vehicle enthusiast groups (Nissan, Suzuki, Subaru, Volkswagen/VAG group, Subaru again, now Kia/Stinger). I have a natural interest in automotive topics (I'm just wired that way), so I've picked up a lot - but that's taken, let me see, I got my first Nissan when I was 19, and now... it's been over 20 years.
If the Dynamat Xtreme is /12" thick, then you'll need to work out the thickest Dynaliner that will fit on top of it without compromising your ability to do things like load your spare wheel. Be aware that the Dynaliner is quite compressable - a spare wheel will compress it very flat even if you choose the thickest option. Without having a Stinger yet - how much space is there between the top of the spare wheel/tyre combo and the boot/trunk floor when it's sitting in place?
If you can get a cutoff of some, you can probably test with that!
I'm not familar with the Luxury Liner Pro - but you certainly want something self adhesive, you don't want to be gluing stuff in manually.
When do do install the self-adhesive products, really make sure you follow the installation instructions - you want your installation surface REALLY clean, and you really want to get a roller for installation to press down on the product to ensure good adhesion - it won't work if it's not securely fastened to the surface you're trying to reduce sound transfer from/through.
Not sure. I chose it as a premium product (it was recommended to me by my preferred car audio installer).
Good sound insulation mean you can listen to your music softer - you get less background noise. A quiet car interior is really nice, irrespective of your music listening habits - sure, damping panel vibration helps when listening loud as well (because it stops unwanted vibrations and sound reflections), but almost any car can benefit from good sound damping (as long as you're willing to accept the weight penalty - I wouldn't do it in a dedicated track car!).
Although not a single product, I think these two may fit the bill at a much nicer price point. What do you think Manaz?
https://www.amazon.com/dp/B00URUIKAK/ref=cm_sw_r_cp_api_i_WHH7CbDNEZ3HP
https://www.amazon.com/dp/B07FYLM47D/ref=cm_sw_r_cp_api_i_uIH7Cb7FXE4FK
