Using OEM pads on a roadracing track will never work with any car, let alone one which weighs 4000+ lbs.
You need to be using dedicated roadracing pads at the track, which by the way, will not work on the street since you'll never get enough heat in them, plus, they'll squeal like crazy.
For our Porsches at Road America we choose to run Pagid Orange and are very happy with them. The OEM Textars wouldn't last 1 lap where one is braking from 150 mph going into Turn 1, Turn 5, and Canada Corner.
Therefore, install track pads first and then determine your braking needs.
With all that said, a 4000 lb car is not a very good choice for tracking. You will/should be burning thru tires, rotors and pads like crazy unless you drive like a grandpa.
Finally, I would strongly encourage you to buy a book on car prep for roadracing.  The basics include proper brake fluid, bleed intervals, brake pads/rotors, dedicated set of track rims/tires, pressures, etc.
