MerlintheMad
10000 Posts Club!
That will work as long as the rotors don't have cementite buildup on them: this only occurs if the rotor surface reached 1200-1300F degrees. Cementite is rough, a lousy heatsink and it grows worse with age, because it is much harder than the surrounding iron of the rotor surface, therefore it stands "proud" (higher) while the softer iron wears down. Brand new pads will not bed in on rotors with cementite: but rather will accumulate pad deposits on the higher cementite surfaces. You have to replace rotors with cementite.Now the deposits are on the rotors themselves so these front pads won't alleviate the shuddering unless I get the rotors turned also correct? Then i'm assuming these ceramic pads will still require the proper bed in process after I get the rotors turned?
