DBLs — Dark spot in the center of beams?
Discussion in 'Kia Stinger Lighting - Inside and Out' started by VA_StingerGT2, May 15, 2018.
  1. Mach_Tuck
    Mach_Tuck United States 1000 Posts Club!
    1,029
    266
    88
    Phoenix, AZ
    Not an issue with the spot...our issue is that the headlights are pointed too low in the default position. My beam ends approx 60-70 feet in front of the car.
    i was also told they dont know how to do it. If the manual adjust is not there, the only other option is to program or code it in. They will have to hook up to the ECU and do this. I am hopeful this is a "new car" issue and not one of complete ineptitude on the dealers part.
  2. TwistedOrca
    TwistedOrca United States Active Member
    My dark spot...
    • Agree Agree x 1
    • Informative Informative x 1
  3. patriotsfan82
    patriotsfan82 United States Member
    38
    6
    Nashua, NH
    I have the same spot - just the way the headlights are designed I think.
    • Like Like x 1
    • Agree Agree x 1
  4. Mach_Tuck
    1,029
    266
    88
    Phoenix, AZ
    Agreed, its normal.
    glad to see your beams are aimed correctly too!! Initially, mine would have terminated in the middle of that intersection.
    FWIW, the dealer does not have to program this...remove airbox and there is a 12mm bolt on back of light housing that can be used to adjust beam height. Detailed in another thread but wanted to update my last post here also.
    • Like Like x 1
  5. 4WDlifeform
    4WDlifeform United States Member
    47
    34
    Searched and found this thread. I also notice the "notch". It seems to land directly on the on-coming lane, like a courtesy to not blind the oncoming person with THEIR high beams on!!! Picture I took on the highway last night:
    [​IMG]
    [​IMG]
    The above picture is facing my garage door. The little dip about a third of the way over from the left of the edge of the garage door is where the black spot projects. My stinger is a GT1, not sure if the headlights on it are different than the GT2? But, the posts above are very similar sounding to what we are seeing.
  6. patriotsfan82
    38
    6
    Nashua, NH
    My GT1 headlights are like this exactly - down to the notch appearing directly in the oncoming lane.
  7. Taimaishoo
    Taimaishoo United States Active Member
    288
    201
    Bossier City, La
    It is by design. The black spot is for safety. If you notice where the spots are when driving on a highway/interstate, there is a dip in your headlights right about where oncoming traffic is, as well as the traffic ahead of you. The dips are to lessen the glare of your headlights while in traffic.
    • Useful Useful x 1
  8. Vohspeach
    Vohspeach United States Member
    20
    4
    Brooks Ga.
    This is great info. I have only had my car for 5 days and driving at night I noticed this black spot. I had NO idea WTH that was! Thanks
  9. Callum
    Callum United States Stinger Enthusiast
    559
    173
    Atlanta
    The dip in the beam is a DOT regulation, that cannot be removed for DOT certification. I'm not sure of the legality, and why some cars require it. It's fairly straightforward to remove it, just open the headlights and dremel the piece off. It's a cast aluminum part that sits infront of the cutoff shield. I plan on doing this mod to mine, as it's pretty bad looking.
  10. Doel
    Doel United States Stinger Enthusiast
    995
    233
    Birmingham, Al.
    It's probably because our headlights are so dang bright they blind people otherwise. Headlights with lower outputs don't need this modification.
  11. Mach_Tuck
    1,029
    266
    88
    Phoenix, AZ
    Id be interested to see how this goes. Everything i have read says that the housing is sealed. Is it possible to remove the projector from the housing to do this mod.
    I have done similar on my M3 so that the cutoff line is much sharper than normal. Very similar, basically smoothed out a notch on the cutoff shield. Made the cutoff razor sharp and added a nice hint of blue to the cutoff line spectrum to boot!
  12. Callum
    559
    173
    Atlanta
    These headlights are most likely butyl blue, opening them should not be difficult. It appears the front lens is moulded into the lens holder. Making a clear lens swap very tough, but polishing them would be quick work with proper machines, which I have access too. I’m not sure what LED projector is used, but they are a open top design so makes me think it’s something already on the market and we’ll know (Koito)
  13. eflyguy
    eflyguy United States 1000 Posts Club! Staff Member Moderator
    2,335
    812
    Georgia, USA
    I would definitely like to remove the notch. In sweeping left-hand bends, it blacks out the lane you are in perfectly..
  14. Callum
    559
    173
    Atlanta
    I’ll report back. I’ll also look at removing the amber marker too. Looks like you may be local, I’ll keep you posted so you can check out the inner workings
  15. Mach_Tuck
    1,029
    266
    88
    Phoenix, AZ
    Highly interested in this too. I am ok with the amber led but the reflector has to go.
    Clear lenses would be great, have done that in the past to BMW as well and makes for much better light throw!
    Best of luck on this project.
  16. Callum
    559
    173
    Atlanta
  17. Mach_Tuck
    1,029
    266
    88
    Phoenix, AZ
    • Like Like x 1
  18. Doel
    995
    233
    Birmingham, Al.
  19. eflyguy
    2,335
    812
    Georgia, USA
    I'm up near Woodstock in Cobb County. I was going to see PresserTech tomorrow but they had to reschedule due to a hardware interface problem.
  20. Callum
    559
    173
    Atlanta
    I wonder if they will do a 2 for 1 deal :)
    I'm in Roswell. If I wasn't so lazy I could kayak to 400 from my house.
Draft saved Draft deleted
Share This Page
