DBLs — Dark spot in the center of beams?
Discussion in 'Kia Stinger Lighting - Inside and Out' started by VA_StingerGT2, May 15, 2018.
  1. VA_StingerGT2
    VA_StingerGT2 United States Newish Member
    7
    6
    Does everyone with GT2 DBLs also have a noticable dark spot where the two headlight beams meet in about the center of the roadway in front of you? Wondering if there is way to eliminate that spot. Are my headlight beams out of alignment perhaps?
    • Like Like x 2
    • Agree Agree x 1
  2. TwistedOrca
    TwistedOrca United States Active Member
    Wow, thought it was just me...mine does.
  3. Zotto
    Zotto Canada Active Member
    159
    Airdrie Alberta
    Its the eyes of your stinger! I like mine especially when the assisted cornering beams look both ways on start up :thumbup:
    These are by far the best head lights i have ever seen/used on a stock vehicle... Enjoy the uniqueness.
  4. BIGRED
    BIGRED Canada Active Member
    Absolutely normal
  5. Kamauxx
    4,096
    1,538
    Yep, perfectly normal. Exact same headlights that have been used on the 17-current SXL Optimas.
  6. VA_StingerGT2
    7
    6
    Thanks all. Just one more thing to get used to in the new ride!
  7. JCranford83
    JCranford83 United States Member
    33
    37
    Lancaster, PA
    I have same black void...also my headlights without high beams don't seam to be providing much visual distance. At night they seem to be directed on the bumper if car 1 car length ahead. I'm guessing only about 25 foot of light...is it possible my headlights need adjusted? Anyone else have this issue?
    • Like Like x 1
    • Informative Informative x 1
    • Optimistic Optimistic x 1
  8. jdouga
    jdouga United States Active Member
    373
    144
    I have a gt1, same thing w mine, i think their meant to be that way
  9. JCranford83
    33
    37
    Lancaster, PA
    Scares me at higher speeds at night...I really can't see a safe distance ahead if/when high beams drop back. Going to call the dealer tomorrow and have them adjust them.
    • Agree Agree x 1
  10. Falaris
    Falaris United States Active Member Sustaining Member +
    199
    189
    Virginia
    I have no idea if this is correct but after a few months of looking at the notch I believe it is probably used for limit settings on the right and left adjustments for the DBL's. They probably aim it at a wall with a horizontal grid and track the right to left angles with the notch. Again it is a guess and I cannot find anything to back that up. I do see many others complaining about the notch and the reduced distance they can see with the low beams on.
    I am not having that issue with mine but am possibly more tolerant than others. I think the Stinger headlights are some of the best I have ever seen in a vehicle and am very happy with them. I would suggest keeping on the dealer until they are adjusted to your liking. You should never feel unsafe driving your car at night!
    -Fal
  11. robz32
    robz32 United States 1000 Posts Club! Staff Member Moderator Texas Stinger Swarm
    2,441
    997
    Houston, TX
    The notch is to prevent glare from blinding on coming traffic. Also I am very pleased with the illumination and brightness of the headlights. Having driven multiple cars with factory HID systems, these LED headlights are hella brighter :cool:
    • Agree Agree x 4
  12. Falaris
    199
    189
    Virginia
    Is that explained anywhere? I searched all over for some explanation about the notch. It just does not seem large enough to me for that purpose. But it sure sounds plausible I guess.
    -Fal
  13. Mach_Tuck
    Mach_Tuck United States 1000 Posts Club!
    1,029
    267
    88
    Phoenix, AZ
    Mine are the same way...id estimate the beam "hits" the ground 50-60 feet in front of the car. Def below the bumper of a car in front of me.
    i went to dealer and asked for adjustment...their response..."we dont know how to adjust them on that model" So, i am waiting for them to figure it out by calling Kia Corp today. There are adjustment "channels" in the engine bay but they are empty on the LED headlights. That is, the standard halogens can be manually adjusted. Apparently the LED lights need to be programmed or coded. Such a joke that i cannot simply turn the know a few turns to fine tune this.
    Agreed on safety...i will continue to have them adjusted until i feel safe with the light spread at night! Any slight incline in the road and the lights may as well be off at their current setting.
    Hopefully dealer calls today with a solution.
  14. JCranford83
    33
    37
    Lancaster, PA
    I'm at the dealer now...fingers crossed. I did tell them there's a video on the forum if they can't figure it out. Lol.
  15. SEA Stinger
    SEA Stinger United States Active Member
    447
    272
    68
    Seattle, Washington
    Headlights on mine are excellent, both low and high beam. Very bright, and long "throw" of forward illumination.
    Sounds like your headlights clearly need adjustment.
  16. JCranford83
    33
    37
    Lancaster, PA
    Dealer looked for about 45 minutes, and then I was told there is no option to adjust my GT2 headlights any higher.
    If anyone knows of a way please let me know!!
  17. SEA Stinger
    447
    272
    68
    Seattle, Washington
    It sounds more like your dealer's service department doesn't know how to adjust the headlights. When lazy or inexperienced mechanics are stumped by something, they are prone to claim it's not possible.
    I suggest you call another (hopefully nearby) dealer's service department and ask if they know how to do it. More to the point, ask if they have experience raising the level of headlights on a Stinger.
  18. JCranford83
    33
    37
    Lancaster, PA
    I contact Kia Support...they are to get back to me tomorrow.
    • Like Like x 1
  19. SEA Stinger
    447
    272
    68
    Seattle, Washington
    Good thinking - smart move!
    Please let us know how this turns out.
    • Like Like x 1
  20. Volvowith18psi
    Volvowith18psi United States Active Member
    173
    54
    Yea keep us posted. I remember seeing that spot my 1st night of ownership and thinking it was a dead bug. havent driven at night since, but I too would like that spot removed.
Draft saved Draft deleted
Share This Page
