The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
BMS Kia Stinger Performance Dual Intake - Kia Stinger dot comInteresting. I've searched but unable to find it on the products page. Mind if you share the link?
TIA
I think they drop ship from BMS, though. So that still won't work.
If I remember correctly, @Terry@BMS claims that the outlet of the box is a restriction. The piping from the box to the turbo is supposedly OK. It would be interesting if we could better identify and rectify that, in my mind, for those who don't want to hear the intake and blow-off noises. There could be a cheap solution, too. But I've not yet looked into it - winter here!Are the factory airboxes that restrictive? The panel filters look to have enough area to provide more than enough airflow with high flow filters in the boxes. I'm wondering if the Velossa ducts/scoops and K&N panel filters would be the most efficient setup for real world closed good driving while maintaining stealth(don't put the K&N stickers on the car) for warranty work. The sealed box eliminates ALL radiant heat from the filter. The factory and Velossa scoops when combined with the sealed boxes ctually create a Ram Air effect which can help keep the turbos spinning in theory.
I'm not quite sure why all the open box style even have the edge seals since it doesn't seem to press up against the hood from what I've seen.
The AP intake looks like it could be the best following but still not sealed. I'm looking at this from a performance and warranty standpoint.
I just emailed Sal, and he said he is able to sell/ship to CA residents.
Why the switchReceived the BMS intake yesterday. Fast shipping as usual from Sal. Will be installing this weekend and the k&n typhoon will be listed in the classifieds soon.
Why the switch
So I actually had a DIY intake system which is great but also got a bms intake... haven’t put it on because it needs powder coating and the cones are much smaller than my DIY.. so I’m going to mess around with my set up and see if I can utilize the piping and shield from bms and somehow use my larger red cones which look really nice against the yellow car ... but i was wondering how the sound is on the smaller cones ? Is it still pretty loud ? My large cones are like jet engine sound hahaI wanted the BMS from the get go for cosmetic preferences and to stay consistent with my jb4, but I was having difficulty sourcing one in CA (stricter laws I suppose). I found a K&N and it seems fine and I doubt I will notice any difference compared to the BMS.
Probably go with yellow on the piping and possible yellow on the shield or maybe a red or black... depends on how my set up works out.. might not even bms stuff.. I want to but it depends how everything fitsWhat color are you powder coating the pipes?
Ill share my thoughts once I install the BMS. At a glance, the BMS filters do look smaller compared to the k&n cones. k&n over stock, its noticeably louder, definitely hear a jet like whoosh under WOT, followed by the blow off sound.
Best of both worlds, I’ve had no issues with it.
Where he cut the hole still goes through the oem filter first.My impression was that the restriction was on the turbo side of the filter. If you've cut an opening on the turbo side of the filter, you've just opened your turbo up to all kinds of dirt, etc., even water.
Did you find a restriction? Is the outlet side of the box smaller diameter than the inlet? Sorry, I'm just not getting what it is you're trying to tell me.
Then it doesn't fix what I thought @Terry@BMS was saying is a restriction about the OEM intakes.Where he cut the hole still goes through the oem filter first.
