itguy61
Nick had been saying some were coming. Maybe he will respond to my question.
Is anybody going to offer these, what is your thoughts?
Very interested to see what stoptech will release, the centric part is a 105 series which is equivalent to the stoptech 308 (street) I think. 308 would be too mild an application in my opinion, most likely better than the OEM but the braking system in this car does seem to generate quite a bit of heat, the 309s would be a better fit.Yes stoptech/centric already has the part number/ dimensions
They are eta end of this month to early coming
Any update yet, Every few weeks I scour FB groups and on here to see if I missed some kind of announcement.Yes stoptech/centric already has the part number/ dimensions
Looks at this Lexus ISF Rear Pad....
very close in measurements!
I’ll order up a set of cheapies to see if it fits. Looks promising, and the ISF has huge aftermarket support.
A little birdie told me that the rear pads are the same as '18+ STI rear pads, just without counterweights..
Edit: in which case, there should be a LOT of options available in the near future..
That akebono part is the same as the 350z which measure 76x65mm, way off our 103x73.If this is correct, the Akebono number should be ASP961
KNS Brakes is listing a lot of rear pad options for the Stinger:
KNS Brakes
Sexy.
I used to only buy pads from KNS when I had a WRX.
I want to report in that the Akebono front pads are lightyears better than the stockers. Not even a close contest...brakes now feel like they should.
asp1001??
which ones did you get?
