Hockster
I trimmed the hoses to fit. Didn't need to remove much at all.
I had that happen once or twice when I first got them. Made sure to really get them on straight and tighten the piss out of the clamps, haven’t fallen off since (over a year ago).With your AEM CAI, any issues with filters slipping away from their plastic adapted?
I’m re-torquing once every two weeks to prevent filters to fall off :/
I’ll be ordering better clamp to apply better torque but I was curious if anyone else saw this issue...
Here’s some pictures, the close-ups are showing the gap on the adapter, when installed and torqued it is sitting @ 0.125’’ from the small edge on the plastic adapter, which bumper is about 0.125’’ as well. The pictures was taken about a week after I took everything apart for a good reinstall & retorque...
Thx all!
Same here... even wrote to AEM for assistance and barely got an answer to my email with no solution even if I provided pictures and details...My AEM filters keep popping out. Any solution? First I did snug, then firm, then tight!. Still pops off.
Try taking the oil lube off the inside of tube I haven't done so but I will try next timeSame here... even wrote to AEM for assistance and barely got an answer to my email with no solution even if I provided pictures and details...
I’m waiting for warm weather to get officially here and I’ll upgrade all the clamps to spring loaded model and should be able to forget these filters...
I did try to wipe it clean, dried it up, even heated the rubber to get it softer so the clamp can squeeze easier... almost broke the worm-clamp because of torque applied... still falls off...Try taking the oil lube off the inside of tube I haven't done so but I will try next time
I saw a YouTube video. The guy used sandpaper to dry it.I did try to wipe it clean, dried it up, even heated the rubber to get it softer so the clamp can squeeze easier... almost broke the worm-clamp because of torque applied... still falls off...
The plastic adapter should be more anti-slip... that would solve everything...
