Staff member
You are also missing the button that turns it on. It should be in between the seat heater controls. My guess it's at best a 50/50 shot of the wiring being there. They obviously have to switch the line over to make the American version of the car. There are a ton of differences. If they are switching the line over anyway it is not hard for them to omit the camera wires. It all depends if the harness for the power mirror includes the wires for the cameras or not. My guess is not..
The Stinger without surround view camera doesn't even have a dummy button there? Otherwise, I didn't even think of that. I was figuring the additional software/aftermarket system would have you select on or off through the navigation screen...
My guess is that the surround view processing is also done by a separate hardware module, not software inside the Kia head unit, since it's probably fairly CPU/GPU intensive to bend the fisheye views into straightened, merged images.
I'm still really interested in the possibility of adding one of these aftermarket solutions (which I linked to earlier in this thread). Aside from drilling a hole in the mirror bottom, the rest should be no more challenging than running stereo or dashcam wires, and the module is supposedly plug-and-play with the RCA inputs on the factory head unit. I think the 360/SVM module simply preempts the regular display when video is initiated, and my guess is that's the same thing the OEM SVM is doing (either activating upon reverse, or manually with the button). The Rear View Safety company even markets directly for the Kia Sorento, so they might be able to make a quick entrance into the Stinger aftermarket.
I think it could be a very popular custom option - ESPECIALLY if the 2019 Stinger doesn't have it...
