Marc Collins
1000 Posts Club!
I wonder if this is also true in other drive modes, such as Eco?
Drive modes do not change anything about the engine or the power it delivers. They only change the throttle response "curve." I don't know the exact numbers, of course, but ECO probably has a fully linear throttle meaning that if you press the throttle 5% or 45% or 85% you get 5%, 45% or 85% of the throttle/power. All sport modes do on almost every car in the world that has them is bend that curve so that more of the power is applied with less throttle input. So, you press 5%, but get 10% of the power, 45% and get 60%, but then by the time you get to 85% or 90%, you are actually getting less power because you already got it (used it up) with less pedal application. Some cars, like Toyota and others are famous for using this approach as a default even on cars with no modes. Those are the vehicles that you get in and immediately think, wow, this car is peppy! Then, some time when you actually need full power and press the pedal to the last 20% of it's range, you realize there is nothing there...
Huge turbos from the olden days that produce huge power gains are slow to spool-up and come in with a bang. You get almost nothing in boost and then suddenly wham, you are scooting forward. The Stinger is the complete opposite (as are most turbos today). It is designed so the boost is a smooth and seamless as possible--in fact, 99% of people wouldn't even know it was a turbo based on a blind-fold test. It just feels like a larger engine than it is. This is the pinnacle of good automotive engineering (for a road car).
