KLR STINGER
- Mar 31, 2018
You're pretty knowledgeable...how much PSI do you think the Stinger can handle?
Map 2 is 4 PSI in all RPMs. I was thinking of editing map 3 to produce 5 PSI in lower RPMs (<3000) and 4 PSI in the higher range. Thoughts?
I haven't yet determined if the stock pistons and rods are forged yet, but I would think 18-20 psi total should be doable. That is probably the extent of the compressor efficiency of the turbos anyhow ( assuming they are something like a garrett gt1752), and all told with supporting mods ( DPs, intakes, intercooler, exhaust) should get you close to 480- 500whp. I would recommend starting small, logging as much as you can and adding from there.
