The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Be very careful! Many have tried and failed. I’m leaving mine on as I like the look on people’s faces when they realise it’s a Kia!I like the E, but decided to go w/Brenthon badging for now. Need to figure out what's involved with removing the Kia badge from the steering wheel. Let's see what my good friend Google has.
Is it the light? The edges look crinkled.The lighting outside doesn't do it justice from the glare. I tried to block the bright light outside the car but I ended up with a lot of glare and reflection. Looks awesome behind the steering wheel!
Before:
After:
I noticed that little bit of a crinkle when you are trying to get it to conform on the bottom edge mostly. So after sitting for a bit I went back out in the dark to take another pic and that crinkle is gone. I think it's the way the badge tucks under and it doesn't have quite enough surface to attach to. It is solid and looks great to me. I don't plan to mess with it. If for some reason it doesn't want to stay on I'll remove it, but I think it will stay right where it is. Here's another pic:
Yup, I think so.looks like its fitting properly , the key is a clean surface and some heat to encourage adhesion ..................
Just a follow up, after fitting this early today, I have now removed it, it was a personal choice & have decided to keep the KIA Logo on display.
Unfortunately this did not want to stay on. I went out this morning and about half of it was detached from the steering wheel so I removed it. I will look at a different option...looks like its fitting properly , the key is a clean surface and some heat to encourage adhesion ..................
which steering wheel badge is giving you the problem?Unfortunately this did not want to stay on. I went out this morning and about half of it was detached from the steering wheel so I removed it. I will look at a different option...
The script from the above post.which steering wheel badge is giving you the problem?
Yes this was partially my problem, quality not that good, crinckled edges & front face remained tacky to touch even after cleaning.The script from the above post.
