EK1Pro Tune - Sixth Element
Have you used or seen the pattern on other brand spray nozzles? I used to use bms nozzles theres a huge difference in atomization. Id also step up to 14gph
definitely a difference in the atomization of mine vs those
if I have to order it I will, but just wondering what would cause the issue of trims. Is the JB4 having an issue or is the FSB the issue?
I would think when the meth is spraying it should drop at least a little even if the atomization wasn't great
here is a log with 2 different BEF's
Are you still using the old 21 deg bef?
Are you sure? I see ignition timing hittting 21
I was under the impression it was the 19 one.
it is the one that was labeled JB4 RACE IGN BEF_CENNDM_U_N2B
Your deff on the old 21 deg flash as its hitting 21 deg peak every time and it has no shift timing. Id email terry and send him that same log. Have him send you an actaul race bef or e85 bef. Race is only supposed to hit 17 deg & e85 19 deg
Any thoughts on the kjt nozzle? How good is it?
Its too much meth. The step down to a snow 14 gph seems about perfect
Just ordered it from Amazon, with my 6% discount for using my amazon credit card, plus various rewards points it was only $35 and shipping is free.
It’ll be here Thursday.
