7thSonEngineering
- Oct 26, 2024
okay I reread your message and checked out an installation video of the Jb4I meant to specify only swapping the JB4 sensor “inputs”. And still plugging the “outputs” in the correct factory locations. Now you would have to break the loom on the JB4 harness to separate the wiring. From what I can tell IAT mod is just wiring to trick the car into reading temp at the charge pipe before the T/B and not the intake manifold after the T/B. Right or wrong?
Yes doing this would effectively create this mod. To do it properly would require relooming the jb4 wire harness to swap the two “input” wires.
This mod would still work with the JB4 and eliminate the need to reloom the JB4.
Factory female harness > Mod harness > JB4 input > JB4 output
