Hi all!
Here's a follow up to my May 2023 posts where the dealer replaced the right side headlight, but did not even check the driver side desiccant pack, so I replaced it.
So, just 7 months later I checked both sides, and both desiccant packs are hard as rock.  The right side had expanded enough to twist the bracket out of shape so I replaced that with a spare I ordered back in May.  That one had the bracket installed with the prongs facing inward (toward the wheel well).  The bracket with the prongs facing outward did not have to be replaced.
So, I'm going to order some more desiccant packs and plan to inspect every 6-12 months, and replace if needed.
