Mine wasn't quite that low, but I tested it somewhere in the 12.2-12.4 range, after normal drives around town (say 10 miles). Given how new my car/battery were, and that I never had a slow or weak start, I figured this must be part of the "smart" charging logic.Wow. 20km/12 miles of errands in town today. The charger shows a state of discharge. . No AC, no heat, no headlights View attachment 86122View attachment 86123
540CCA STD? what battery is that?Wow. 20km/12 miles of errands in town today. The charger shows a state of discharge. . No AC, no heat, no headlights View attachment 86122View attachment 86123
My OEM Kia stinger battery is AGM90L-DIN (850CCA)I Googled the standard OEM battery of the 2022 Stinger. If that was an erroneous input on my behalf, I will accept corrections to my input. Any help is welcome. I will amend as required.
Thank you for your attention to my possible error!
I appreciate your reply with relevant information. Thank you. I will test again tomorrow.My OEM Kia stinger battery is AGN90L-DIN (850CCA)
That might give you different readings on that battery analyzer.
Yours is likely the same
Trips to the dealership resulted in them telling me that the battery was seriously discharged, but they wouldn’t replace it under warranty because their testing equipment said to recharge, not to replace the battery.I appreciate your reply with relevant information. Thank you. I will test again tomorrow.
Do you leave the car unlocked at home? I don't have the spec in front of me, but I believe the discharge current is notably higher while the car is "awake", dropping off a short while after you lock it and it goes to sleep.I understand that there is probably a good amount of discharge while at rest, something has got to be on standby in order for the cell modem to engage to the app when requested. Seems like it has a mind of its own.
I recently purchased a BM6 Bluetooth battery monitor that "CLAIMS" to draw less than 1.5mA (which is insanely low)Do you leave the car unlocked at home? I don't have the spec in front of me, but I believe the discharge current is notably higher while the car is "awake", dropping off a short while after you lock it and it goes to sleep.
I was leaving the car unlocked in my garage when I noticed the lack of Coasting and measured the lower voltages. You could also grab a multimeter with induction loop and see what the car is pulling from the battery while off.
You'll need to put the multimeter where you can see it in the hatch, close and lock everything, and give it a minute or so to settle.
Does not require internet access.Does the app for above require internet connectivity? Does it report anything back to the mothership?
Maybe you are expected to add your own??Where's the fuse?!@#
I guess it would need to be inline with the car's cabling (or use an induction loop) to measure current draw, unless it can back into it from the rate of voltage drop.I recently purchased a BM6 Bluetooth battery monitor that "CLAIMS" to draw less than 1.5mA (which is insanely low)
I always lock my car nearly immediately after parking, so I can't really speak to the parasitic draw when left unlocked, or how long it takes to go to sleep. But I am sure it does go to sleep sometime between 30 and 120 minutes after parking, if left unlocked. Much quicker when locked.I guess it would need to be inline with the car's cabling (or use an induction loop) to measure current draw, unless it can back into it from the rate of voltage drop.
Have you been able to observe a different rate of drawdown with the car unlocked/awake vs locked/asleep? I would've assumed that even unlocked the car would eventually go to sleep, but maybe not given my voltage dips overnight.
