Ric 'Ochet
- Feb 1, 2021
what are the offsets? my TSW offsets are 40 in front and 39 in rear, 8.5 in front and 9.5 in rear. I like how those tire sizes your choosing work together, with the rears c. 4mm bigger OD, that seems sensible since the rears wear down quicker staggered than the fronts do, and it always bugs me that the OEM setup starts out 2mm smaller in the rear.Sent TSW Mechanica wheels (19x8, 19x9.5) I purchased via FB Marketplace to have road rash repaired and powder-coated graphite color. Ordered Michelin PS A/S 4 replacements 235/40/19 and 275/35/19. Can't wait to see what it looks like on my pumpkin!
Just checked them out. I keep finding more online stores like this that have no address, phone number or email contact. Makes me feel a little uneasy, like they have something to hide. Puts you at a big disadvantage if there’s a problem with your order. No BBB, etc.Ordered more CARBON Fiber from Seoul Carbon!
Bury it!! No seriously from the looks you should be able to get the extra drop you wantGetting ready for a alignment taking out a little rear camber from 1 1/6 neg to 1/2 deg neg rear tires are wearing a bit fast on the inside. However decided to lower the front another 1/4 inch in height debating a 1/2 inch right now, Night time Pic not the best, right now no rubbing or driving issues View attachment 86519
About to tackle the water pump myself. It was idling in the garage and I heard the bearing making a weird noise, so I ordered a new pump from kiapartsnow.com. for $188. Haven’t heard the noise since but I’m sure it’ll start again. That chchchchch noise always comes back. lol. . Anyways I’m rambling. Do you happen to know the part numbers for the 2 water pump gaskets? Any tips? Thanks in advance.Finished work earlier today, and decided to tackle leaking oil filter housing, oil cooler, cooler lines and serpentine belt. But once I removed the belt, I noticed some play in water pump, so decided to replace it as well, since I had the parts laying anyway. 130k miles. Took me another 30-40 min to bleed the system. View attachment 86141View attachment 86142View attachment 86144View attachment 86147View attachment 86143
Your going to have to. did you get the recall on the Telly yet? a fire hazard associated with the power seat adjustment button and the seat jamming and burning out the electric motor. the recall affects vehicles throughout the Telluride's production history, not just limited to a year or years.Nothing major. Just oil changes for both. Royal Purple 5-30 w factory filters. The Telluride is a quicker job w the filter and drain being accessible by only having to drop a small shroud. It’s 15 vs. 20 min. Not really complaining, because I don’t trust anyone but myself. I haaaaaate letting someone else touch my vehicles.
Hell yea! Gotta post a full side shotWell tucked it as far as I can without causing any driving issues so far so good have a few test days before the alignmentView attachment 86549
No, I dont remember any part numbers. As far as any tips, there's none realy. It is pretty straightforward process. Tighten the bolts to the specs, and make sure you have hex bit sockets for one of the bolts.About to tackle the water pump myself. It was idling in the garage and I heard the bearing making a weird noise, so I ordered a new pump from kiapartsnow.com. for $188. Haven’t heard the noise since but I’m sure it’ll start again. That chchchchch noise always comes back. lol. . Anyways I’m rambling. Do you happen to know the part numbers for the 2 water pump gaskets? Any tips? Thanks in advance.
Actually my wife told me this morning about a fire hazard/ recall. But she had no other details. I’m gonna def look into getting that handled asap. Thanks
Thanks for the pic w torque specs. I’m sure the dealer can pull up the the correct part numbers. Hopefully. Maybe.No, I dont remember any part numbers. As far as any tips, there's none realy. It is pretty straightforward process. Tighten the bolts to the specs, and make sure you have hex bit sockets for one of the bolts. View attachment 86568
