Snowwhite
Sustaining Member
- Feb 3, 2020
If you find that it turns on sooner when You turn in one particular direction, the fault is probably with a wheel on the outside of the side where it turns on faster. So if it turns on faster when you turn left, check the right side first.This is great progress. I’ll give this a try as well. Thank you for sharing this information as well! I don’t know much about this kind of stuff but patience is key.
Something I noticed while driving today is that the TC would turn on when driving in a curve. I’m assuming it puts more weight on one side of the car and the car thinks there is wheel spinning. I dug a little deeper and started doing some semi harsh-ish lane turns (in an empty freeway of course) and sure enough, TC kicked in. Give this a try next time you are driving.
Also, do you have a picture of where to find the abs sensor contacts?
