Juan.s.003
- Jan 7, 2024
Recently, I encountered an issue with my car. When I am on the highway and start getting to around 75 to 80 mph, the traction control light starts to flash and all the sudden I lose power and the car just starts to slow down. As you can see in the video, I am pressing the gas pedal all the way, but the car is not responding and the revolution start to go down as well. If I let go of the gas pedal altogether and press it again, traction control light turns off and I am able to start accelerating but the same thing will happen again once I start to hit that 75 mph speed. Anyone know why this is happening? This happens in every mode except sport mode. In sport mode, this issue doesn't happen at all and I can go past 80 mph.
I was told there was a fuel pump recall which may or may not be the answer to my issue but when I called the dealer they said there were no active recalls on my vehicle. I am out of warranty as well so I can’t take it to the dealer.
Also, I’m not sure if this has anything to do with the issue but one of my front bumper sensors fell off so I’m in the process of replacing it. The dash says “check system” for the front sensor. Not sure if this correlates with my issue but I just had to put it out there just in case.
Anyone know what else could be causing this issue? I don’t entirely believe it could be because of a bad fuel pump as it drives with no issues on sport which makes it all the more confusing.
