Slip_Angle
- Feb 3, 2019
@I'm Tony Danza - Did you ever get this figured out?
Never did. I used the Chassis Ears on around 60 points throughout the suspension, drivetrain, brakes, subframe, mounts....you name it. Comparing both sides of the car at the same time. Nothing ever jumped out as being obvious. I could have easily missed something, but hit all the major spots. I may try again after winter.@I'm Tony Danza - Did you ever get this figured out?
It's from the front end, unfortunately. Not a bad idea for those who have a noise from the trunk area.Try taking the round tool insert out of the spare tire in the trunk.
Yeah, just did a tire rotation and the noise is there even with my OEM 18" wheel/tire setup, albeit a tad more quiet. Wish that was the case!Did you take it to a tire shop to check and see if the tpm didn't break off inside the wheel I heard that noise before on a camero and it was a broken tpms rolling around inside the wheel
Still haven't found the problem. Do you have suspension mods or stock? AWD or RWD?Any updates regarding this? Have you replaced the control arm bushings? I have a similar problem - replaced both front strut assemblies, next are the control arms
f*ck me I have the same sound . It's definitely suspension related ..Got the same issue, did anyone ever fix this problem ?
