As the owner of a base gt, I feel completely opposite then you do. I've had sunroofs and T-tops on basically every car I've owned, even the Lightning has that smaller window that I open to let air in. I absolutely hate not having a sunroof. I'm kinda used to it now but it's one of the more glaring negatives to owning the base trim level. The others imo being no power tilt steering wheel and the horrible 7" screen. At least that I was able to swap/change, no swapping in a sunroof lol.
Other things I'd want done differently.....
Having the option to turn off the beep when I lock/unlock the car. The lights flashing is enough, don't need both.
Why doesn't my rear window defrost when I remote start the car? Isn't that the whole point?
Functional hood with heat extraction
Better sounding stock exhaust
Having stock wheels be square 19's, with different wheel options. Would be nice to be able to rotate the tires without buying aftermarket rims. Basically all gt's got the same rims unless you have a indigo blue, scorpion, grand tourer or the tribute. I feel like most cars have a couple different options of wheels to choose from, no? All Camaro, Mustang, Chargers have the same 1 factory wheel option?
Having the option to customize the screen display, background etc...
Slightly larger gas tank without the locking fuel door lid. That damn lid likes to freeze shut in the winter. I'd be fine with a regular ol lid that I can manually open.
A 2024 beyond model
Having the "special edition" cars with different themes. Not just a mix and match parts bin appearance package.
gts all carbon fiber trim inside/out
Indigo blue woodgrain interior trim to go with the brown
Scorpion/Grand Tourer all gloss black trim inside/out
All with - 400hp/400tq stock.
