D.J.
2500 Posts Club!
- Feb 24, 2018
- Location
- Toronto, Ontario, Canada
Can you share a picture?Is it critical if almost all teeth are being broken?
None of the teeth should be broken
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Disagree strongly .If you’re breaking the teeth off the gears you are obviously doing it wrong. Stop and pay the dealer to do it because you have no business doing it yourself.
I adjusted my headlights myself because the dealer's adjustment was still too low.If you’re breaking the teeth off the gears you are obviously doing it wrong. Stop and pay the dealer to do it because you have no business doing it yourself.
I would NOT recommend adjusting your headlamps L/R. There should be a factory installed lockout feature on the L/R adjuster. Optics engineers work years to get the headlamp pattern correct. Adjusting them U/D is ok, but if you over adjust that you can cause glare issues for oncoming traffic. I wouldn't think there is any reason to change the factory L/R setting, doing so can lead to a large dark spot in the foreground. If it was me I would leave L/R alone (you might not be able to adjust them anyway).So, is it possible to move low headlight beam to right/left? Mine MY18 GT2 also has a blank L/R holes.
What does this factory installed lockout look like? any pictures?I would NOT recommend adjusting your headlamps L/R. There should be a factory installed lockout feature on the L/R adjuster. Optics engineers work years to get the headlamp pattern correct. Adjusting them U/D is ok, but if you over adjust that you can cause glare issues for oncoming traffic. I wouldn't think there is any reason to change the factory L/R setting, doing so can lead to a large dark spot in the foreground. If it was me I would leave L/R alone (you might not be able to adjust them anyway).
I was initially happy driving in the city with my adjustment, but last night I drove in dark, unlit country roads and found the beam too a bit too short. So I pulled over to the side of the road, popped the hood open. deployed my #2 Philips screwdriver. and pointed my headlights a bit higher.
It was so simple and easy. i was done in just a minute or so. I didn't even need a flashlight to see the little holes in the dual-funnel. It's almost as if this was meant to be user-adjustable.
Now, how anyone could break the teeth is beyond me. As with any screwdriver, a little pressure should be applied to ensure the screw head and the driver are constantly in contact while turning
Perhaps South Korea didn't add them. Or they aren't present on the motor. For SAE markets, headlamps with manual horizontal adjusters, lockouts are mandatory. It's a little shield that's installed on the horizontal adjuster that prevents access to the phillips head. I've not worked on a headlamp program for a long time that's slated for CCC markets. Maybe the regulations have changed?What does this factory installed lockout look like? any pictures?
My 2018 does not have any factory installed lockouts.
Lockouts or no lockouts, I still don't recommend changing the factory L/R settingWhat does this factory installed lockout look like? any pictures?
Last headlamp I was involved with that went to multiple overseas markets was the 2015 Ford Edge, a halogen projector headlamp.Perhaps South Korea didn't add them. Or they aren't present on the motor. For SAE markets, headlamps with manual horizontal adjusters, lockouts are mandatory. It's a little shield that's installed on the horizontal adjuster that prevents access to the phillips head. I've not worked on a headlamp program for a long time that's slated for CCC markets. Maybe the regulations have changed?
What is SAE markets?Perhaps South Korea didn't add them. Or they aren't present on the motor. For SAE markets, headlamps with manual horizontal adjusters, lockouts are mandatory. It's a little shield that's installed on the horizontal adjuster that prevents access to the phillips head. I've not worked on a headlamp program for a long time that's slated for CCC markets. Maybe the regulations have changed?
I strongly recommend adjusting the left/right adjustment - if it is out of alignment.Lockouts or no lockouts, I still don't recommend changing the factory L/R setting
I respectfully disagree, but how on earth would a headlamp's L/R factory settings become out of alignment other than a collision? Additionally, the factory settings are done in final assembly by computerized aiming systems, not something you can accurately recreate at home.I strongly recommend adjusting the left/right adjustment - if it is out of alignment.
You would not be changing the factory settings, you would be adjusting to the factory settings.
Details on correct alignment are here --> https://www.kstinger.com/headlamps-790.html
Yes, can become misaligned during a collision.I respectfully disagree, but how on earth would a headlamp's L/R factory settings become out of alignment other than a collision? Additionally, the factory settings are done in final assembly by computerized aiming systems, not something you can accurately recreate at home.
That's understandable now. However I still would not recommend people "play" with the L/R adjustment unless something like what you mentioned happens. Even with U/D, people need to be careful. ie doing it up against a wall with the vehicle on a level surface and no extra weight in the car other than the driver. IIHS and Consumer Reports (forgot to mention that rating system earlier) measurement happen on flat surfaces with poles located in precise locations for standardized, non-moving measurements. Then there's a night drive when engineers pile into a mule with lights mounted according the the new vehicle's dimensions and evaluate the beam pattern for down road visibility, the foreground illumination and for light/dark streaks in the pattern.Yes, can become misaligned during a collision.
Same as a wheel alignment.
I had one of my headlights replaced under warranty - I then adjusted it myself to factory specs, cause kia dealerships generally suck.
If you notice OEMs are starting to place truck headlamps lower on the vehicle, dividing up the LB/HB and DRL functions, this is a direct response to IIHS ratings. It's not that the LED lamps are that much brighter (there are limits) it's the color temperature of LED and their higher placement, resulting in glare for oncoming traffic. If you are sitting in your passenger vehicle and there's a truck across the intersection whose lights look extremely bright, then you've experienced this phenomena. Once they turn then you will likely see that the HB (always the inner lamp function) is not illuminated.Then the IIHS ratings are broken down into "good", "acceptable" and "poor". Those are mostly based on beam pattern performance, balancing downroad punch to glare, or sometimes called "dazzle" for oncoming traffic. There are even standards for "sign lighting", so if you have a halogen reflector, certain facets of the reflector are aimed up and to the right to illuminate signs.
Thank you. Your this post made it much easier - the second time.I just did the adjustment on my lights using the "horizon" method. It was super easy, using the "funnel" and the long-shank screwdriver referenced above). Took maybe 2 minutes each side. I'm anxious to see tonight how they do on the road.
For the record, my 2020 GT2 has headlight centers ~28" from the ground. I marked out the same height on the back wall of the garage, and parked the car at ~20'. Adjusted the lights up until the tops of the "hot spots" were at 28". The hardest part of the whole process was finding a screwdriver that would fit the darn hole!
