HoosierStinger
You don't have to remove any components. The steering rack hangs there by the tie rod ends. Removing the 4 mounting bolts will save you many cuss words. But that's my opinion. Good luck with your projectI will try to get it done without removing the sway bar or the steering rack first, but if I failed I will be dropping things and cussing bc I'm working on a G80 sport AWD it might have a slightly more room than the Stinger and the G70.
And omg the old diff fluid stinks, it's smelled like a crusty septic tank.
