BMS WMI kit questions
Use the JB4 with our back end flash map if you're looking to max things out while still having tuning flexibility, advanced safety systems, etc.
That's why I'm spectical about an actual ECU tune, I can't change anything about it once I get it, and knowing Lozic and other tuners they all have timing corrections problems. So I might just buy a meth injection kit from BMS and see if I could run map 3 on 93 octane without any corrections.
That's a good start. Then add our BEF later if you need more flexibility or want more power.
Anyone know the tap size for the bms wmi 1 gallon tank? Directions state 1/4th npt. I've seen install videos that stated 1/8th-27 npt
Check to see which fitting we shipped. I think the current ones are 1/4" NPT.
It was 1/4" NPT. The confusion came from an installation video I used for assistance that had a different fitting for the tank. I assume one from a previous version.
