Aftermarket Wheels
What is Your favorite Wheel?
  • Total voters
    235
Anyone know what offset they ran on this set up?
These gorgeous TSW aluminum alloy wheels scream performance and open the view to those impressive factory Brembo brakes. Our favorite configuration is the staggered 20 x 8.5 up front and 20 x 10 in the rear. Combine them with the Falken AZENIS FK510 245/35ZR20 and 275/30ZR20 respectively, and you are making a powerful visual statement while enjoying an exhilarating driving experience. Our TSW Sprint is also available in a staggered 19-inch configuration if you would rather run the factory tires.
I want to know if a taller profile can work without lowering to fill wheel gap with this 20" setup.
30 front 40 rear. I’m dumb I found on the TSW Fitment app
They are 19" Vossen Classic 5s with Toyo R888R tires.
Really nice. Don't forget to show us a picture when mounted on the car. ;) What width and offset have you chosen?
Have anyone tried the following setup without rubbing issue? Not lowered.
20x8.5 +25, 245/30/20
20×10 +35, 295/25/20
Wouldn't choosing 245/35/20 and 275/30/20 exceeds original diameter by too much?
It will look badass but the ride will be very tough.
Tough meaning noisy and rough? I've not been to such aggressive setup before hence no experience.
Another safer setup which I might choose is 19x8.5 +25 255/35/19 all round.
The tyre sidewall is very small so I meant that you will feel all the small bumps in the road.
F2359110-0DA5-48B0-AF09-8DB82EEF453E.webp 37B0E635-6FBF-4513-BB93-B6788BF0D9A0.webp
I tried putting on 18x9J +20 offset, with 265 rubbers and they won’t work on the fronts. +25 offset on 8.5J might just make it but I would be cautious
That aggressive tire protrusion is awesome. But you are going to throw dirt and grime up your sides like a beast. That's why I want a wide body kit. Just meaty tires aren't meant to fit under it at OEM dimensions.
It will fail our local inspection.
Giavanna HALEB - 20"
@187STINGER 's car -20x9.5 front 20x10.5 rear
