These gorgeous TSW aluminum alloy wheels scream performance and open the view to those impressive factory Brembo brakes. Our favorite configuration is the staggered 20 x 8.5 up front and 20 x 10 in the rear. Combine them with the Falken AZENIS FK510 245/35ZR20 and 275/30ZR20 respectively, and you are making a powerful visual statement while enjoying an exhilarating driving experience. Our TSW Sprint is also available in a staggered 19-inch configuration if you would rather run the factory tires.
I want to know if a taller profile can work without lowering to fill wheel gap with this 20" setup.
That aggressive tire protrusion is awesome. But you are going to throw dirt and grime up your sides like a beast. That's why I want a wide body kit. Just meaty tires aren't meant to fit under it at OEM dimensions.
