Canadian Stingers with JB4 - What fuel?
Just log it
I will log it today and share . Did some pulls yesterday on map 3 and Shell 91 , wow, the stinger just transformed into a whole new beast...went upto 22psi...
Interesting, I get better timings with ultra 94.
Does your shell have any ethanol or no?
Whereabout are you from Canada?
Hi, Based out of Brampton/Mississauga in Ontario. Shell 91 here has Zero ethanol. I tried to log but since it was first time, did not seem to do it right and it is a pretty long file lol. But here is a screenshot ( I did sort descending )
Set your JB4 to auto log at 75 -80% throttle then do a run from third gear to about 140 K. Post log. I guarantee your timings will be crap on 91 fuel.
From Kitchener, cant recall if our shell has zero ethanol.
But do what billy suggested and report back
This morning on the way to work.. not the best conditions but here are the results... Damn..the 4.16s was invalid due to slope, but truly the road looked flat lol
Draggy can be finicky due to low satalights. Doing em on a cloudy day is a hit or a miss lol.
Were these on map 3?
Yes, map 3 , Shell 91 . Will try on a warmer non-cloudy day and post :)
Did you compare them with map 2 timings?
That is pending :(
Can someone help with some instructions for a newbie on how to run the logs on jb4 ? Thanks
Lunch time, peppy drive ! Looks like my best so far...4.15s
Hey, How are you ? I need some help ( step by step for a rookie/dummy :) ) on how to log (driving conditions ? ) and send the csv to Burger... Thanks
Logging is pretty easy! if you want to take a log, just make sure the JB4 is installed correctly, connect to it via the app on your phone, then hit start logging on the main screen! when you are done, hit stop. Then you can go to the logs tab, click on the log you want to send (the most recent one is at the top of the list) and email it to Terry@burgertuning.com
Alternatively, you can also post them here in the JB4 support thread and other members like myself can assist in reading them as well.
@StingerbyAdoom , This helps. I did see some complex (for me ) notes on some pulls in a certain gears etc ..so Was not sure... Thanks ! Much appreciated !
Disregard above advise!!
Step one; Go into JB4 app set JB4 to log at 80% throttle.
Step two; Set JB4 to map1
Step three; go to SAFE road do a WOT run from 3rd gear to about 90 ish or 145 ish for you kph folks.
Step four; post log.
There ya go, knock yourself out.
