JSolo
2500 Posts Club!
I have one of those cig lighter volt meters. Will observe next time I drive somewhere. 2.5 Probably has similar behavior. Good logic, no? Why rob hp when its needed for accel.
phone app for sureI think the Stinger gives a reasonable compromise between mileage and performance. I'm generally getting about 25-26 mpg, plenty of gas sucking traffic due to the gross ineptitude of TX DOT construction and some interstate miles.
I would like to know how to get the gauge presentations you show. I have a GT1 with of course the 3.3L TT. Thanks, Don
The past 10ish years I keep a plug/patch kit, plus a compressor in my car. Work trucks/etc around here tend to be pretty lazy with cleaning up after themselves and leave crap all over the roads. I think in the past 10 years I had to either repair (puncture was near the middle) or replace tires (too close to sidewall) combined about 6 or 7 times. Rarely have needed to use my spare after keeping those on hand.Mine went from 60 psi to 50 psi in over a year between inflating. My first (so far only) time using the spare was a month ago, and I was worried beforehand that it would be too low to be useable, since it had been a while when I inflated it last. But 50 psi is plenty.
Once got a flat tire (not in the Stinger), and when the tire shop pulled the tire off, there was the shaft of a screwdriver inside.The past 10ish years I keep a plug/patch kit, plus a compressor in my car. Work trucks/etc around here tend to be pretty lazy with cleaning up after themselves and leave crap all over the roads. I think in the past 10 years I had to either repair (puncture was near the middle) or replace tires (too close to sidewall) combined about 6 or 7 times. Rarely have needed to use my spare after keeping those on hand.
Random things I've picked up besides the usual nails/screws.....utility knife blade, hunk of iron/steel. Oh and a giant rock in the middle of the interstate that I wound up hitting because a cop flipped his siren real quick to "warn me", which did the opposite and distracted me long enough to hit the rock, bending the front AND rear wheels of my previous car.
The gauges are smartphone app called https://www.carscanner.info/ (I have an android phone but the app exists on both platforms). I have tried several, I like this one the most.I think the Stinger gives a reasonable compromise between mileage and performance. I'm generally getting about 25-26 mpg, plenty of gas sucking traffic due to the gross ineptitude of TX DOT construction and some interstate miles.
As far as I can tell - my Stingers charge voltage only drops to a reduced level when the battery is fully charged, and the engine is warm (and probably some other conditions).^^So that 300 mile nonstop highway trip will do squat to recharge the battery.
I bet other conditions will trip the alternator to charging mode too. Seat, steering wheel heaters on, rear defogger, fan on max (maybe).
Our '15 accord did some funky stuff with battery charging too - only when high load accessories were on, otherwise it was barely over 13v.
I suspect your battery is fully charged nearly every single time you park your car.I know with my short commute. I would be a fool to shut her down right away. But sitting idle in a driveway with the brake on should make the alternator charge correct?
No. You see. (With my truck). I had a 5 year battery that lasted 3 years. Because the commute is so short it never completely recharged the battery from start up. Over time the battery will fail due to discharge. The commute is a mile an a half. Not enough for an alternator to completely recharge the battery. Hence the idle time. So far so good.I suspect your battery is fully charged nearly every single time you park your car.
I wish my commute was that shortNo. You see. (With my truck). I had a 5 year battery that lasted 3 years. Because the commute is so short it never completely recharged the battery from start up. Over time the battery will fail due to discharge. The commute is a mile an a half. Not enough for an alternator to completely recharge the battery. Hence the idle time. So far so good.
My battery took a shiiiitter after 2 1/2 years. I too rarely drove it and when I did, it was short 2-5 mile trips.No. You see. (With my truck). I had a 5 year battery that lasted 3 years. Because the commute is so short it never completely recharged the battery from start up. Over time the battery will fail due to discharge. The commute is a mile an a half. Not enough for an alternator to completely recharge the battery. Hence the idle time. So far so good.
Comes in handy with 5 bucks a gallon. Now I pay what the long commute people paid. Don’t even want to think what the long haulers pay.I wish my commute was that short
Not sure if it really opens the vents, or just that when you crack the sunroof vent, you have provided an exhaust for the vents to flow without backing up.This is my first car with a sunroof, and since it's been pretty hot recently I have used the sunroof vent function to help hot air escape the car after its been parked for a while.
I had no idea enabling the vent function would also open the dashboard air vents to allow outside air to enter the car. I was along the highway and noticed a good amount of air coming from the vents, even though the climate control system was off. I closed the sunroof and the airflow stopped from the vents. When I reopened the sunroof using the vent function, the airflow resumed from the vents.
I dunno if other cars operate the same way when you use the sunroof vent option, but I thought this was interesting and made sense. Its probably in the manual but I never bothered reading up on the sunroof section lol.
