So not as easy for those of us with T shifter & boot. I could never find a way to get the T and Boot to lift up as this will help ALOT. Nonetheless I had to leave the shift side in and unscrew it with the whole trim piece after pulling the trim piece out on the Korean one as I pictured above.
The new piece you must install to the trim and shifter piece then at the end install the
cup holders as last thing as for some reason I could never get it to fit if
cup holders were already on there.
A lot of laying on side and back trying to get to screws to work underneath while holding it up.
HIGHLY recommend placing a long towel over the opening to catch any dropped screws as I found my magnetic phillips wasn't strong enough. Dropped 4 and recovered 3. Panic attack ensued once everything was back together I couldn't shift it. Come to find it one of the lil bastards decided to jump into the shifter. After checking everything felt in there and felt the little turd. Thought I was going to have to tow it as I could not get into gear or it would stick in a gear or tear the whole shifting area apart. After about 30 stressful minutes I was able to final get it to move and settle elsewhere hoping doesn't reoccur.
