killinghall
The question remains. How many AWD owners have had defective transfer cases and what contributed to their demise?
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
you are right, I've noticed it also.I bet it broke in the same place in all the waves - the lowest or highest point (depending on how you look at it) of each bend
That's an excellent question. I would certainly be concerned about it and wouldn't want to run in that configuration for extended periods of time. A few runs on the dyno would be fine, but a bunch of track time probably wouldn't.So if you pulled the AWD Fuse is there a risk of damaging the transfer case as there isnt any active lubrication due to the pump not running?
Or (excluding the input shaft and output shaft to the rear) because the piston isnt apply pressure almost nothing is moving in the transfer case to the risk is negligible?
While reading this has been a blast and incredibly informative, currently, I know of an AWD GT line that runs all the time in RWD, from 100 miles or so to about 30K now, that has had 0 issues with it. we don't know how the internals look of his specific unit obviously but he has no issues so far, which makes me think that maybe the pump still provides oil to allow lubrication even if the clutches don't engage, and that the AWD fuse is a circuit specifically for the clutches? Just a thought though.That's an excellent question. I would certainly be concerned about it and wouldn't want to run in that configuration for extended periods of time. A few runs on the dyno would be fine, but a bunch of track time probably wouldn't.
It also depends on how much splash lubrication happens. It's hard for me to tell where the fluid collects and returns to the pump. So if the front output gear is actually sitting in fluid and constantly splashing it back upwards then that would help. But, wet clutches need constant lubrication (when disengaged) or they can glaze or burn.
This also assumes that fuse just controls the positive side of the pump and the ECU/TCU controls the negative side via a PWM control. That's the simplest way to do this kind of thing, so seems most likely.
Well, if he runs *all the time* without the fuse, then he'll never know unless one of the bearings actually fails. The clutches might be toast which means they won't engage properly, which means that case might never engage AWD again. A lot of "might"s in there.While reading this has been a blast and incredibly informative, currently, I know of an AWD GT line that runs all the time in RWD, from 100 miles or so to about 30K now, that has had 0 issues with it. we don't know how the internals look of his specific unit obviously but he has no issues so far, which makes me think that maybe the pump still provides oil to allow lubrication even if the clutches don't engage, and that the AWD fuse is a circuit specifically for the clutches? Just a thought though.
Should I tell him to pop the AWD fuse in for a week and see if the car acts up at all then? hes a stock Gt line so its not like the dude is pushing any kind of power lolWell, if he runs *all the time* without the fuse, then he'll never know unless one of the bearings actually fails. The clutches might be toast which means they won't engage properly, which means that case might never engage AWD again. A lot of "might"s in there.
I agree that not running the pump probably won't cause a critical failure that stops the car from driving. It will probably damage the transfer case which will stop it from working properly.
Although, the gear attached to the basket must ride on needles. Could be a bushing, but given what we've seen and what's typically used in a manual trans, I expect a cage with needles. Those are more tolerant of limited lubrication than a bushing, but it certainly could overheat and fail.
¯\_(ツ)_/¯Should I tell him to pop the AWD fuse in for a week and see if the car acts up at all then? hes a stock Gt line so its not like the dude is pushing any kind of power lol
the way the dude drives it, their wont be a next owner.¯\_(ツ)_/¯
We all make choices in life. It'll probably just be an adventure for the next owner. Especially if it's some poor soul who ends up in a snowy/icy climate.
Front wheels will still turn the transfer case internally so that wont help. When pulling the fuse it just doesn't send power to the front wheels.Should I tell him to pop the AWD fuse in for a week and see if the car acts up at all then? hes a stock Gt line so its not like the dude is pushing any kind of power lol
Check the u-joints on all the drive shafts for play. There's also a guibo (flex joint) in the middle of the driveshaft going to the rear differential - make sure that's still in good shape. Also check the engine and transmission mounts for excessive movement.yes, on my case I still have some knocking sounds coming underneath while driving.
in short: my assumption was for transfer case, and indeed, it had broken spring flaying around clutch basket, I replaced it, took all clutch packed, put the transfer back, and still have some sounds... maybe the same I had before, maybe different, have no idea, it's hard to judge.
That sure sounds like a u-joint to me. But I haven't examined the driveshaft in my car and certainly haven't taken it out. Taking a look at the line drawing it appears they actually use CV joints on the driveshafts? That's nicely complicated. You would need to actually remove the shafts (or fully disconnect them) and check all the articulation to see if one ball has failed or trash has gotten into the boot in one space.I checked drive shafts, flex point, mounts, they seems good.
Also I measured frequency of the knocking sound, and it's two times more than the frequency of wheel rotation.
In other words, while the wheel makes one rotation I can hear 2 knocks. And it's true for wide range of speeds, from 10 miles up to 50 (then it's hard to heard the knocks due to noise from the driving).
So, two impulses per one rotation...
And if I put transmission into neutral gear while driving and the engine would drop its RPM, the knocking does not change.
But you may be right, and it's just transfer case producing that noise.
