Very niceBought new wheels and tires for summer!
If you run map 0, that is completely disabled, running stock.I disabled my JB4 and am running around in eco mode because apparently my ignition timings are all messed up![]()
Probably best to do the rear when well rested and more patient.Got my front sway installed.
Have the rear just waiting, but not tonight.
True words ! I said some bad words while installing my rear bar.Probably best to do the rear when well rested and more patient.![]()
Well rested yes, patient, probably not gonna happen.True words ! I said some bad words while installing my rear bar.
No different really than the mishimoto, BMS, jlt, or really any other OCC kit for these cars on the market. They all mount in the same area. There are also factory hoses that are much closer to the manifolds than the OCC hoses. Is that to say there isn't that possibility. I suppose it still could happen but that's why you check for leaks and keep an eye on it closely for a couple hundred miles and make sure everything is still good. Just like with any mod really.I can't believe that the mounting kit positions the OCC directly over the exhaust manifold. Looks like a recipe for an engine bay fire to me.
Hoses
True but we are talking inches there. That area is going to get hot regardless. I guess we will see. If I start getting leaks then I'll post a update here for those that are running the SXTH OCC. Hopefully it doesn't go up in flames before I notice it.Mishi sits off to the side more compared to the one you have which is directly over the exhaust manifold. But if you're OK with it..
Ask any woman, every inch matters!True but we are talking inches there. That area is going to get hot regardless. I guess we will see. If I start getting leaks then I'll post a update here for those that are running the SXTH OCC. Hopefully it doesn't go up in flames before I notice it.
After months of looking at wheels with a staggered stance, I finally decided to go with a square setup as well. What offset did you go with?20x9 with 255x35 squared. Sits pretty flush without spacers
