JSolo
2500 Posts Club!
I suppose getting AA to full screen is a positive step. Seemed like a waste for only using 2/3's of it. Next they need to implement the wireless AA.
Going to have to try this later. I did appreciate that it did the update while the car was off.Didn't make any developer changes in mine. Here are settings.
View attachment 70860View attachment 70861
I think the "Split screen on" logic takes into account that the split screen gives part of the screen to AA, and part of it to built in apps that you can select (maps, weather, compass, etc). Disabling split screen technically gives up the entire screen to AA and leaves the logic to AA on what it'll do with the entire screen. It definitely seems like reverse logic, but also kind of makes sense.^^ Clearly splitscreen on == 0 and splitscreen off ==1. Reverse logic, like the forward/back tracks with the steering wheel control.
They got rid of the tubesI will not be updating if they got rid of the tubes. One of my favorite features of the infotainment. They are referring to the image of the vacuum tubes in amplifiers. Anyone have an image of what is there now?
Anyone figure out how to get the audio to fade out? Did the update in my 22 and wasn't doing it. Thought it may be because I had that welcome/exit sound on so I turned that off and still no luck.
Don't accidently turn on the stereo when updating. I did and it got stuck on a Spanish language station in-between frequencies at an uncomfortable volume. I couldn't turn it off, turn the volume down, or make any adjustments. About thirty minutes later it finished but wow, that was an experience.
The thirty minutes was the time in-between when I pressed the power button and when it got to the point of the update where it shut off. I was easily running the update for 30 minutes before my fatal button-pressing escapade.What an exercise in watching paint dry! It's been ~2 weeks since they released the 2nd update, they didn't pull it, so decided to update mine.
In post 1236 you said it too took over an hour. I'm confusedwhere did the 30 min come from?
Did it with the car in accessory mode with the battery tender connected.
Mine took 70 minutes from the time I pressed the final start on the touch screen. At the start, it said eta 25 min.!@!!@# RIght!
The longest was the initial step (1/5), the actual map data update. It after each section is completed (according to the bar indicator), it then either extracts files or validates the extracted files. That is, it was stuck at 100% of part 1 for a good 12-15 min or so.
Nice to finally get full screen android auto. Maybe next year we get wireless!
Re radio station display. It is a bit of a shame they took away the original bulb like digit display. Probably wanted to get the displays consistent between models. Less programming involved if that section is uniform. Would of been nice if they let the user decide. Adding presets seems easy enough, deleting requires multiple touches (no swiping of the station from the list). Is there a quick way to delete presets?
Still no way to turn on day time map color when it's dark (like in my garage).
With split screen off (no check mark), I get the full screen AA, with it on, 2/3's is AA, right 1/3 is one of the car's screen (media/radio, clock, compass, etc..). I'm not sure why Devin's is reverse ¿?I think the "Split screen on" logic takes into account that the split screen gives part of the screen to AA, and part of it to built in apps that you can select (maps, weather, compass, etc). Disabling split screen technically gives up the entire screen to AA and leaves the logic to AA on what it'll do with the entire screen. It definitely seems like reverse logic, but also kind of makes sense.
That's the exact behavior I saw regarding both the split screen check mark plus full screen only on the 1280x720 option. If I left the resolution setting to the default as well as leaving the split screen check box unchecked, AA automatically splits the screen to have two AA apps on screen (Waze and music player for me).With split screen off (no check mark), I get the full screen AA, with it on, 2/3's is AA, right 1/3 is one of the car's screen (media/radio, clock, compass, etc..). I'm not sure why Devin's is reverse ¿?
Edit: Re AA full screen, that only worked with the 1280x720, 720x1280 option, not 1920x1080. According to the nav manual, it's 1920x720. Hmm...
