does anyone know disabled DTC will let you pass inspection with this tune? i live in PA, currently have P0420 code because of the maintec downpipe and tried to install a o2 spacer but it throw other codes(P013A and P0090)
Someone awhile back in this thread had an emissions issue, and from what I remembered had to just swap back to the stock ECU temporarily to pass.does anyone know disabled DTC will let you pass inspection with this tune? i live in PA, currently have P0420 code because of the maintec downpipe and tried to install a o2 spacer but it throw other codes(P013A and P0090)
thanks for the reply, I forgot to mention that i dont have the ecu tune lol, my stock ecu had the code, so im thinking getting the ecu tune to get it disable completely but idk what it will shows on the inspector's readiness monitor (fail, incomplete or ready)Someone awhile back in this thread had an emissions issue, and from what I remembered had to just swap back to the stock ECU temporarily to pass.
Sorry just realized you need to clear the O2 sensor code. When I was running catless in an older vehicle of mine, I reset the ECU parameters. The 02 sensor was the last one to reset out of the 6 (from what I remember you needed at least 4 of the 6 reading as "good" to pass) parameters that emissions looks at. So essentially you had a window to take the car through when every other diagnostic was showing as "good" and the O2 was still in the process of reading.Someone awhile back in this thread had an emissions issue, and from what I remembered had to just swap back to the stock ECU temporarily to pass.
There's a bunch of guys with downpipes and other various exhaust mods on here, someone has to have a definitive answer for you.. but from my knowledge, modifying the ECU can remove the check engine light but as far as emissions go the underlying code is still there.thanks for the reply, I forgot to mention that i dont have the ecu tune lol, my stock ecu had the code, so im thinking getting the ecu tune to get it disable completely but idk what it will shows on the inspector's readiness monitor (fail, incomplete or ready)
YES I just tested it today, while cruise control works, I get "---" as the mph it set to. ughHas anyone else had the cruise control “problem”
I wonder if it’s all of them and I’m just too damn picky! Maybe it’s not fixable.YES I just tested it today, while cruise control works, I get "---" as the mph it set to. ugh
That would be me. it still is crazy.I had someone tell me it was crazy that factory was that much.
I am willing to bet there is more with the same problem.I have a swapped cluster from GT1/2 into my GTS... not sure if thats an issue.
Where did you get the 7in supervisor?I have a swapped cluster from GT1/2 into my GTS... not sure if thats an issue.
EbayWhere did you get the 7in supervisor?
Mine works great. I have a GT2 and cruise speed is displayed both on the MFD and the HUD.I wonder if it’s all of them and I’m just too damn picky! Maybe it’s not fixable.
Dang wonder what the deal is for some.Mine works great. I have a GT2 and cruise speed is displayed both on the MFD and the HUD.
Yeah I got mine last Friday and mine has displayed fine. No issues at all.Dang wonder what the deal is for some.
Have you asked Lozic? I'm sure he can fix it. Do you have a GT2?Dang wonder what the deal is for some.
No mine is a base GT. We had other things to change in the tune. I told him, but he actually didn’t respond to that part. Just said he would make all other requests.Have you asked Lozic? I'm sure he can fix it. Do you have a GT2?
Yes even sent him pictures. What he say to you?He said i was the 1st to report the issue. Did you notify him Pearly?
