Kimberly Lazarski
You may wash the car immediately after parking it. Think about it; if rotors actually did warp under less severe conditions than Merlin mentioned, they would be encased in a sealed module with an active cooling system rather than installed outboard at the hubs where they _WILL_ be subjected to splashing and even immersion in very cold water while driving (rain, snow, and puddles are things). Any time you think your rotors might be warped, remind yourself that vented rotors rarely if ever warp. They are more likely to deform from a BJs/Sam's Club/NTB tire tech using a half inch impact wrench on the lug nuts than by street-duty heat cycles. _Do_ go for a 15-20 minute drive after washing&drying the car to also dry the rotors to prevent surface rust.Quick question: when are rotors considered too hot for your car to be washed? I know that sudden changes in temperature can cause warping?
If I can touch and keep my hand on the (warm) rotor, is it fine to pressure wash the wheel? Or should pressure washing the wheel be totally avoided?
Thanks!
Don't stand on the brakes while stopped after hard stops from 140mph+ (use park or the parking brake instead), and if forced to creep in stop&go traffic jams or city driving, do the bedding procedure periodically. And, if you park the car outside a week or longer and the rotors develop surface rust, re-bed to strip the rust and prevent deposits.
