Russell Buzz Buzz
- Nov 4, 2019
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
They have different stages. Stage 3 is firm and you will feel the shifts. Stage 2 is in between stock and stage 3. Normal driving you wouldn't notice it but when you step on it, it shifts a lot faster.And how has the TCU tune improved your daily driving?
I have only had them a few 100 miles. Im using M45iL. others are getting 20k+ miles.How long are the HKS lasting and which are you using?
Awesome. What gas are you running?
7k is pretty high! haha. It doesn't boost taper though nearly as bad as JB4 (even with EWG wires). Usually I shift before 6k for 1/4, 0-60 times. Boost just stays as a flat line on the logs. I love it.
Torque does come on a lot quicker with the tune. I had to get used to launching the car and shifting 1st to 2nd because first and 2nd gear go so damn fast now.
I've got 36k on mine and I do a 4th gear pull every fill-up and they are still working perfectly.How long are the HKS lasting and which are you using?
Like no need for CPI then, or? Will probably be enough with E30-35. I tried 35% E85 to 98 RON (yours 93) and also works well and keeps HPFP. Meth seems more to have if we do several runs as the heat will accumulate, maybe also at a 1/4 run. I feel that meth can slower down car a bit if start to early. I did now start meth at 16-17 psi.Here is a log with just CPI and no meth. Pretty much the same data as CPI w/ meth which I expected.
Also, was out and about and had to fill up with straight 91 octane (couldn't find E85). So attached is a log with just 91 octane and meth. Pretty good considering. few timing corrections but not bad at all with highest being 1.5 degree. Def feels a tad slower in the powerband with the overall timing being lower throughout. But the ECU is doing its job and adjusting.
Next logs will be E30 w/ meth. No CPI. Then E30 w/ CPI and no meth.
Well I cant get a full answer yet but from where it stands now, CPI and METH produce the same results so far. One or the other. I would say if E85 is more accessible then go with CPI over Meth. If you don't have E85 locally, then go with WMI.Like no need for CPI then, or? Will probably be enough with E30-35. I tried 35% E85 to 98 RON (yours 93) and also works well and keeps HPFP. Meth seems more to have if we do several runs as the heat will accumulate, maybe also at a 1/4 run. I feel that meth can slower down car a bit if start to early. I did now start meth at 16-17 psi.
Do you use "stock HKS gap", like 0,028" or 0,7mm?
Awesome thread - maybe you can help me out here. At the moment I have intakes and a stage 1 TCU tune. I could maybe do a full exhaust system in the future, but really nothing much more than that. I typically use 92 octane as I get it from Costco around here. E85 is also available nearby. Should I be looking at the 1.5 tune or the 2.5 tune?Depends on octane you are going to run. The 1.5 tune is great for pump gas. 2.5 is great for higher E85/pump gas mix or running WMI.
There are plenty of 11 second cars with stage 1.5 tune.
I have the stage 2.5 because i run E50 with charge pipe injection.
With E85 local to you, the 1.5 tune will be plenty. I am seeing more and more people with 1.5 putting up some insanely fast times on a relatively stock car. (ECU and TCU tune only).Awesome thread and has me leaning heavily towards lap3.
I’m still somewhat new to this so to be sure I’m understanding E85 is used to blend with pump gas to get something such as E30 and that in turns is equivalent to using a higher octane gas correct?With E85 local to you, the 1.5 tune will be plenty. I am seeing more and more people with 1.5 putting up some insanely fast times on a relatively stock car. (ECU and TCU tune only).
bingo!I’m still somewhat new to this so to be sure I’m understanding E85 is used to blend with pump gas to get something such as E30 and that in turns is equivalent to using a higher octane gas correct?
